Car got sort of flooded!!! Need Diagnoses...
Old Jun 9, 2008 | 04:24 PM
VeeL_B20's Avatar
Default Car got sort of flooded!!! Need Diagnoses...
Hello HT,
My EG gsr swap got flooded yesturday, but just enough to fill the floor a couple of inches (about 3"). Had to tow the car home, but started up again today. Speed cluster is dead and the engine light just came on. Car sounds like it is misfiring and bogging out. It feels like it could die any time and has a hard time idling. I figure the water must of short circuit something and got into the motor somewhere. I'm going to check the spark pluggs and the dizzy wires tonight and give an update.
Has this happened to anyone and what did you do to fix it? Engine rebuild?
Any comments or suggestions are appreciated.
Old Jun 10, 2008 | 07:48 AM
standbackimapro's Avatar
Default Re: Car got sort of flooded!!! Need Diagnoses... (VeeL_B20)
Well alot of the time people wil say its hydrolocked, which isnt always the case, i would say change the plugs as alot of the time theyll foul out from running like ****.
check the air filter, make sure its completley dry, change the oil, and if you have a compressor, use an air nozzle and dry off as much as you can
Old Jun 10, 2008 | 11:32 AM
Top Ramen's Avatar
Default Re: Car got sort of flooded!!! Need Diagnoses... (standbackimapro)
You probably got water in the harness. Pull each connector on the lower part of the harness apart and blow it out with compressed air. If that does not work, do a compression check to see if you really did hydrolock it and slightly bent a rod or valve.
Best of luck.
Old Jun 15, 2008 | 08:28 AM
VeeL_B20's Avatar
Well update,
Changed the oil, which was competely black, and did a compression test.
It read 200, 209, 208, 209, so I'm thinking it's about time to do a rebuild, but I'm not too sure if this is really bad. What are your inputs?
Old Jun 15, 2008 | 08:39 AM
JThrasher79's Avatar
those are good numbers..
Old Jun 16, 2008 | 02:18 PM
VeeL_B20's Avatar
Ok update,
Checked my timing and it was off! Timed it right, but now the motor is weak as heck. Thanks for the inputs.
Lee.
99JDMHATCH
Aug 11, 2009 07:47 AM
The Internet Tough Guy
52
Apr 17, 2006 11:59 AM
Madrek
22
Jul 20, 2005 05:38 PM
SIRIUS
May 21, 2005 09:14 AM
