JDM h22a dry 60 shot traction issues... vids included
Went to the track again this past weekend this time around ran some 205/55/14 nitto drag radials .. running varying pressures of as low as 10psi and high as 15 . either way just couldnt get it to hook like id like and it was killing my trap speed lowering the psi anything below 15... i was running 2.2 or so 60s sometimes worse and that is not any better than just runnin my stock tires... i ran a 13.6. @105 2 weekends ago on just the stock 205/55/15 ecsta AST ... but only progress ive noticed the drag radials totally eliminated my violent wheel hop issue.
after watching the vids i noticed the rear end squatting entirely too much my weight transfer is terrible. im on stock springs with kyb gr2s .... this could be my issue can anyone give some insight and some suggestions...
here are the vids enjoy
http://www.youtube.com/watch?v=faVtSigEmdc
http://www.youtube.com/watch?v=vN6N5ruppY4
http://www.youtube.com/watch?v=iHTTOLfG240
http://www.youtube.com/watch?v=Ax_0BYSyxMU
http://www.youtube.com/watch?v=-5KenJzg0x4
launching around 3-4k sometimes spray in first but mainly right when i get into second.... it doesnt matter even if i go all motor runs traction still sucks ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">nice time. whats your elevation? I would invest in some new springs and motor mounts.
not sure of elevation but im down in Louisiana ... and the weather was terrible that day heat around 88-90 with humidity above 60%
</TD></TR></TABLE>not sure of elevation but im down in Louisiana ... and the weather was terrible that day heat around 88-90 with humidity above 60%
looks to me that you need to heat up the drag radials better and launch higher.
make the rear suspension stiff as possible as well to keep the car from sagging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">looks to me that you need to heat up the drag radials better and launch higher.
make the rear suspension stiff as possible as well to keep the car from sagging.</TD></TR></TABLE>
how would i go about making the rear stiffer i cant adjust the kybs i have on the car now ,,, they are just the gr2
naw gr2 are basically stock replacements so u can't adjust them. I am not a expert but look into better springs that puts the front lower than the back and has a stiffer spring rate for the rear. That way when u take off the front wheels are still on the floor other than lifting up and spinning out. and yes maybe some motor mount inserts would do u some justice too. my .02
Hey I'm in BR. Anyways, I would wait to spray later. I can hit about 2.2 60' ft times on BFG g-force sports. Dont just drop the clutch. You have to ease off at first then just drop it. If you are having bad wheel hop try replaceing the front strut/radius rod bushing. Really cheap/easy mod that will help out.
