B16A1 OBD0 CEL's
Old Jul 16, 2002 | 10:51 PM
riceboy's Avatar
Default B16A1 OBD0 CEL's
I turned off my car for about a minute earlier today, then when I started it back up it ran like ****, so I turned it off, would not start back up, check fuel, its OK, check spark, hardly any, replaced the distributor with an old on, still no power at all, all connections are good and I'm throwing CEL's as follows, before I reset the ECU I was throwing 4,7, and 23 I think 23 is for knock, which isnt there, I think one of the others could be for the temperature sending unit, but I dont know, then I reset the ECU and turned the motor on for a moment and it was getting hardly any soark, then it threw CEL #4 and only four what is anyone's opinion on this and if you happen to have a book with the OBD0 B16A1 codes for a 90 Jap B16A CR-X I'd like to know the codes.
Old Jul 16, 2002 | 11:54 PM
sparkz's Avatar
Default Re: B16A1 OBD0 CEL's (riceboy)
sounds like the ignitor went bad. common honda problem
Old Jul 17, 2002 | 04:14 PM
riceboy's Avatar
Default Re: B16A1 OBD0 CEL's (sparkz)
ttt
Old Jul 18, 2002 | 02:55 AM
ULTRA911's Avatar
here you go, and it applies to the b16a1 too.
http://tech.hybridgarage.com/tech/codes.html
Old Jul 18, 2002 | 07:03 AM
riceboy's Avatar
Default Re: B16A1 OBD0 CEL's (ULTRA911)
CEL was for TPS, looked at TPS, it was cracked, replaced TPS, car is fixed
sloweh3
Sep 26, 2016 10:18 PM
DA_9
Mar 11, 2008 03:17 PM
djsire
Mar 21, 2006 12:42 PM
B16Drag
Apr 9, 2004 11:15 AM
