coolant temp sensor?
Old Jun 9, 2008 | 08:04 AM
turbo-crx's Avatar
Default coolant temp sensor?
if the sensor is bad(the one with the single nipple)will it cause the car to over heat or just give a false reading?
Old Jun 9, 2008 | 01:58 PM
1992Si's Avatar
Just give a false reading to the best of my knowledge.
May be somebody knows if the ECU uses that signal to turn on the fan in conjunction with the thermoswitch.
Old Jun 9, 2008 | 02:10 PM
turbo-crx's Avatar
Default Re: (1992Si)
well my fans are hard wired to my ignition.
Old Jun 9, 2008 | 02:21 PM
1992Si's Avatar
I like direct reading gauges for water temp and oil pressure. It either works or it doesn't. They take the guess work out of trouble shooting.
If your serious about performance go with direct reading gauges.
Old Jun 9, 2008 | 02:52 PM
turbo-crx's Avatar
yea, i just ordered one.
Old Jun 9, 2008 | 03:35 PM
Mikey3000's Avatar
Default Re: (turbo-crx)
it'll just give a false reading. that goes directly to the gauge only.
97milanoLS
Jan 13, 2011 06:56 PM
skidmarkroyalty
Jan 11, 2009 03:04 PM
vtecaccord 1
Dec 7, 2004 05:59 AM
SMC Integra
Aug 8, 2004 10:15 AM
ten_30
Oct 2, 2002 11:08 AM
