Always running cold?
Ok so my temperature gauge never moves off the cold side. Also, I'm pretty sure my radiator fan never kick on. But anyways, the lower radiator hose would be warm instead of hot and idle would pulse. And so I replaced the thermostat. Now the lower radiator hose would get hot and idles fine. So I think that helped. But the temp needle still won't move and fan still doesn't kick on. I swapped cluster, and the needle on one that didn't move also. I think I bleed it correctly and the heater blows out pretty hot air. Could it be a sensor? And I did searched.
is the upper rad hose hot? thats were you check for a bad theromostat. but since you already replaced it it sounds like maybe a bad coolant temp sensor or something. you fan shouldnt have to run unless its hot out and your not moving. mine will only kick on at the taco bell drive thru when its 80 degrees out.
Yeah, before I replaced the thermostat, the upper hose would be hot and the lower one would only be warm. And yeah, the fan wouldn't kick on. Like I would let it sit and idle for 30 mins or so to see if it would kick on, but it never did. The coolant temp sensor, it's on the thermostat housing right? And would it throw a cel code if it was bad? But it's not.
jdm_dc_fan
Jul 30, 2008 06:53 AM
