Timing Problem
Old Jun 8, 2008 | 09:49 PM
FOMULA91's Avatar
Default Timing Problem
Went to smog my CRX and Passed visual, EVAP test and the actual emission test but failed timing. Running a JDM D15B VTEC motor as a replacement for a stock CRX Si D16A6 setup. Had it tested 2 years ago and passed fine but this time, my timing was off about 10 degrees. Running the motor with stock PM6 ECU and the TD02U Distributor. Was thinking that the crank pulley timing mark should be different between the Si D16A6 and D15B Vtec motor so if I swap the crank pulley, would that solve the timing problem?
Old Jun 8, 2008 | 10:24 PM
FOMULA91's Avatar
Default Re: Timing Problem (FOMULA91)
Forgot to mention that the CRX is running OBD0.
Old Jun 9, 2008 | 12:09 PM
FOMULA91's Avatar
up....
afnan
Jan 9, 2014 05:45 AM
Pronus
Feb 13, 2006 12:35 AM
wickedEFguy
Oct 6, 2004 02:46 PM
notstock93
Sep 27, 2004 02:07 PM
VisualEcstasy
Apr 15, 2003 09:00 AM
