b16 ef Q's
Old Jun 8, 2008 | 09:35 PM
jdmb20boi's Avatar
Default b16 ef Q's
ok so my buddy has a 90 civic hb with the 99civic si motor swap.. he was getting vtec then he threw a check engine light. so that means no vtec.. but how the hell do you check the code on the obd-0 someone told me a while ago about a paper clip or somthing like that. anyone have an idea?
Old Jun 8, 2008 | 09:54 PM
saikouEF8's Avatar
Default Re: b16 ef Q's (jdmb20boi)
http://www.c-speedracing.com/faq/06.php the FAQ area is your friend. good luck.
Old Jun 8, 2008 | 09:56 PM
1kreationz401's Avatar
yup get a small wire or paper clip....around on top of the ecu you should see a hidden blue harness pull it out and put what ever that ur using...paper clip or wire stick it in and turn car on acc and look at how many times so n so...!
Old Jun 8, 2008 | 10:54 PM
gsrpedro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb20boi &raquo;</TD></TR><TR><TD CLASS="quote">ok so my buddy has a 90 civic hb with the 99civic si motor swap.. he was getting vtec then he threw a check engine light. so that means no vtec.. but how the hell do you check the code on the obd-0 someone told me a while ago about a paper clip or somthing like that. anyone have an idea?</TD></TR></TABLE>
ITS IT OBD0, OBD1 OR OBD2????
Old Jun 9, 2008 | 01:48 AM
gibsanez's Avatar
Default Re: b16 ef Q's (gsrpedro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb20boi &raquo;</TD></TR><TR><TD CLASS="quote">but how the hell do you check the code on the obd-0 someone told me a while ago about a paper clip or somthing like that. anyone have an idea?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpedro &raquo;</TD></TR><TR><TD CLASS="quote">
ITS IT OBD0, OBD1 OR OBD2????</TD></TR></TABLE>
Old Jun 9, 2008 | 12:32 PM
90efsib16's Avatar
ok well i did it but its coming back 2 long blinks then 2 fast blinks the info i found was vtec pressure.. any ideas how to fix this?&gt;
Old Jun 9, 2008 | 12:57 PM
gunnerman's Avatar
Default Re: (90efsib16)
i have an 89 civic hatch with a b16a obd-0.
i didn't have to use the paper clip. there's a light on the ecu and it will blink to indicate the ecu code. long blink = 10, short blink =1.
Old Jun 9, 2008 | 01:11 PM
jdmb20boi's Avatar
iight i got 2long flashes then 2 short flashes then it was a pause then it was 1 quick lil blink then the 2long ones again.. then 2 short ones again.. pleas help me fix this isue..
bigtimegambler
14
Nov 12, 2015 08:32 AM
punkriderf3
10
Jun 7, 2007 07:06 PM
si0385.
Feb 14, 2006 12:27 AM
Quade
Jun 15, 2004 10:27 AM
Eg6_JDM
Apr 26, 2002 10:27 AM
