Fast Turn Signal - Bulb Ok
Old Jun 8, 2008 | 11:44 AM
pcorad's Avatar
Default Fast Turn Signal - Bulb Ok
My 97 R started throwing a fast turn signal last week. So I looked at the driver's rear bulb (front bulbs are working fine) and the bulb looked fine. I swapped the right and left bulbs in the rear and confirmed that the bulb is ok. After messing around a bit more, the blinker started working, so it seemed like there's a loose wire/bad connection.
A week later, I've got the same problem. I broke out my multi-meter, and though I'm mostly dangerous with electricty, I confirmed that there is power coming into the socket, as the needle on the multi meter jumped with each click.
So, it seems like there is power at the socket. The bulb is ok. But the bulb won't blink (or do hazards for that matter).
What to do??
Old Jun 8, 2008 | 12:07 PM
pcorad's Avatar
Default Re: Fast Turn Signal - Bulb Ok (pcorad)
I talke to my brother, the engineer with German cars. He suggested scuffing the contact points with sandpaper in case there was some gunk blocking the connection. Sure enough this worked. Problem solved.
Old Jun 8, 2008 | 02:18 PM
robfrmny21's Avatar
a bad socket will give you the fast blinker thing as well
W95civicEXcoupe
Mar 5, 2015 02:51 PM
burntvalve
Honda CR-V & Element
Feb 25, 2012 06:52 AM
rkrone
14
Aug 26, 2006 06:38 AM
kylem
Jul 24, 2004 03:45 PM
B16ED4G
Feb 27, 2002 07:43 AM
