engine sputter
Old Jun 8, 2008 | 08:41 AM
hojoR's Avatar
Default engine sputter
I have a b18c in my 00 civic. my engine has been sputtering/ hesitant/jerky on idle and acceleration for the past few months, it doesnt happen all the time but it seems to becoming more frequent recently. I have changed the fuel filter, put new oem ngk plugs in, new oem wires, has a two year old distro cap, I have cleaned all the grounds and replaced the old battery terminals, and I have added injector cleaner additives 3 times, and iso-heat gas treatment for water in the gas. But I am still having this problem. check engine light is not coming on. anyone have any thoughts or ideas? much appreciated. Thanks
Old Jun 8, 2008 | 09:03 AM
wigglematoe's Avatar
Default Re: engine sputter (hojoR)
mine was doing that too, i spend money on tune up didnt do any good till i checked my oil, i was really low so i put some oil in and it stopped sputtering i dunno if its ganna help but mine stop after i added oil and clutch fluid =] i was low on it too cuz mine would sputter at 4rpm threw 7 and 8 or sometimes at 6 to 8 dunno you can try to check tho but mine stopped when i added oil and the clutch fluid
Old Jun 8, 2008 | 09:11 AM
hojoR's Avatar
Default Re: engine sputter (wigglematoe)
my oil level is good, I always change it evry 2k-3k. I havent checked my transmission levels recently. whats the best way to check that? I know when I first got my motor I went through a bunch of axels on the passenger side, when the axels started going bad they would slip and it felt like the motor was sputter, maybe thats my problem again.
B-money
May 21, 2009 12:24 AM
mraza
Aug 1, 2006 11:24 PM
EGcivicBoy
May 21, 2006 06:35 AM
JDMF22B
Jun 10, 2005 10:00 AM
Hoya
Mar 7, 2004 06:46 PM
