Something NOT Good WTF?
Old Jun 7, 2008 | 07:19 PM
ThatOneOG's Avatar
Default Something NOT Good WTF?
okay guys i have a weird question, i dont know why but sometimes when i drive my car starts jerking real hard when i throw it into gear and release the clutch. and it only does it sometimes what could be the problem? and why does the gas pedal get hard at the beginning when i try to gas, its real weird and then its regular till i come to a stop it would happen again, now again. it doesnt happend all the time... any ideas?
Old Jun 7, 2008 | 07:26 PM
vsmhatched's Avatar
Default Re: Something NOT Good WTF? (ThatOneOG)
check engine lights?
Old Jun 7, 2008 | 07:41 PM
H22Ej1's Avatar
Shenanigans
Default Re: Something NOT Good WTF? (vsmhatched)
throttle cable issues?, is it stock or swapped? for ur jerking issue are you letting the clutch out too fast/not giving it enough gas? that will cause it to violently jerk
Old Jun 7, 2008 | 07:46 PM
leadfootedfool's Avatar
Could be motor mounts.
Old Jun 7, 2008 | 10:45 PM
ThatOneOG's Avatar
Default Re: Something NOT Good WTF? (H22Ej1)
well it swapped to a b16, na the jerking only happens sometimes. all of this happens all at once, any idea why the gas pedal gets harden?
Old Jun 7, 2008 | 10:58 PM
MidoriBG96's Avatar
the problem with your gas pedal is buildup in your throttle body, take your intake off and clean your throttle body, be sure to open the butterfly valve and clean where it sits against the body itself. That should do the trick
BNSTKSI
Jul 6, 2011 11:44 AM
Juniorhatch
May 9, 2011 11:51 AM
benji7288
Honda Civic (2001 - 2005)
May 22, 2009 11:04 AM
tsouyporta
Mar 16, 2007 04:08 PM
civic91
Oct 23, 2003 12:00 AM
