TPS Question
I recently put a turbo kit on my gsr integra and my tps started going crazy. I am only boosting 4 psi because the car won't take any tuning. The guy that was going to tune it said my car is running so rich, i shouldn't blow anything. I tested my tps voltage with a voltometer and got a .01v at closed throttle no matter which way i cranked my tps. At full throttle i could only manage a 3.1v charge. I was checking the middle black/red wire on the tps. Is this the correct wire to check? And does this indicate i need i new tps in order to remedy the problem and tune my car correctly? Any help would be greatly appriciated
