I need help!! Anyone!!!
Old Jul 16, 2002 | 07:46 PM
** OF HAZARD's Avatar
Default I need help!! Anyone!!!
ok i have a 7thgen civic! I was spraying and something happened car wouldnt start! it turns over but it just wont start. So i took the head off expecting the worst. The cylinder walls are fine. headgasket is fine. i cant seem to find the problem. there also was oil in the intake maifold. Everything seems fine but no compression in the first and second cylinders!? Any ideas? sorry for the long post but please help me or point me in the right direction to fixing this!!
Old Jul 16, 2002 | 07:52 PM
IHaveTurbos's Avatar
Default Re: I need help!! Anyone!!! (7thgencivic)
Did you check your Vavles to see if they are Burnt and not seating right. That would be one of the next things to check.
Old Jul 16, 2002 | 07:56 PM
Default Re: I need help!! Anyone!!! (Hyundai4G63T)
the valves are really clean! The car has almost 40,000 on it and about 2000 of it has been with nitrous! Everything is clean!! Looks brand new you can still see where they honned (sp?) the cylinder wall. There are no visiable signs of where!!
Old Jul 16, 2002 | 08:04 PM
lightning's Avatar
Did you pull a piston? Sometimes there will be a hole burnt in the side of the piston by the ring land that is not visible from the top.
Tom
Old Jul 16, 2002 | 08:15 PM
Default Re: I need help!! Anyone!!! (lightning)
i havent pulled any pistons out!! There isnt any scaring on the walls! So iam gonna put the head back on and do a leak down test!
Old Jul 16, 2002 | 11:02 PM
ttt
Old Jul 17, 2002 | 06:00 AM
88_SC_CRX_Si's Avatar
New User
Have you checked your cam, to see if it's not broken...
Old Jul 17, 2002 | 06:10 AM
When you do the leak down test it should tell you the same as the Compression test but will give you a better understanding of where the problem lies (i.e. Rings, Head Gasket, etc.)
Let us know the results of the leak down.
Old Jul 17, 2002 | 11:06 AM
kinesistech's Avatar
Dont you think a leak down first would have been better than removing the head first.
Old Jul 17, 2002 | 02:44 PM
Default Re: I need help!! Anyone!!! (kinesistech)
Yeah, the leak down would have given you a better place to start at what is really wrong with the 2 cylinder.
cctgene
Nov 5, 2011 01:49 PM
lopezchris21
Feb 15, 2010 08:24 PM
Lamchop0000
28
Jul 7, 2006 06:50 PM
whitelightning
Jul 26, 2005 08:03 AM
Ceres
Sep 8, 2004 07:47 AM
