A/C Issues
Old Jun 7, 2008 | 09:33 AM
Fullthrottle297's Avatar
Default A/C Issues
my hatch never came with AC so i installed everything got it working but the fan never kicks on i tested it and it works also the the line going from the condeser to the evap can and from compressor to the condenser get hot and its not just warm its really hot
any ideas
the system works fine when im moving but when i stop or sit still there is no AC at all
Old Jun 7, 2008 | 10:12 AM
instructor74's Avatar
Default Re: A/C Issues (Fullthrottle297)
what fan the climite control fan inside the car or the cooling fan for the ac unit in the engine bay?
Old Jun 7, 2008 | 10:48 AM
Default Re: A/C Issues (instructor74)
the condenser fan on the outside of the car
Old Jun 7, 2008 | 10:57 AM
itsmejto's Avatar
Condenser fan has it's own fuse in the engine fuse box.
Old Jun 7, 2008 | 11:10 AM
Default Re: (itsmejto)
replaced it 3 times all three fuses werent bad
Old Jun 7, 2008 | 11:36 AM
jadziasman's Avatar
Did you hook up a manifold gauge to the high and low pressure side fittings? You will need to do this to diagnose your system pressures.
Was the A/C system you put in new or used? If used, there could be blockage in the line somewhere.
Check the FAQ section. There's a great write up on A/C that should help you out. You can also download a helm pdf manual if you haven't already.
Old Jun 8, 2008 | 11:49 AM
Default Re: (jadziasman)
the system is used and i havent diagnosed yet so it could be possible that its clogged
going to diagnose will post up results
Modified by Fullthrottle297 at 4:09 PM 6/8/2008
ef8ftw
Sep 14, 2009 09:41 AM
civicman69x
Jul 24, 2008 08:10 PM
92spoonlude
Mar 31, 2007 03:29 PM
albsgsr
Jul 29, 2005 05:08 PM
