Replacing brake master cylinder
Old Jun 7, 2008 | 06:51 AM
Zerophase's Avatar
Default Replacing brake master cylinder
So I did a search and couldn't find anything on this topic.
I need to replace my master cylinder (94 lx) and I was wondering if anyone how hard of a job is it to do with the help of a friend and how long should it take us?
Old Jun 8, 2008 | 05:16 AM
Zerophase's Avatar
Default Re: Replacing brake master cylinder (Zerophase)
bump
Old Jun 8, 2008 | 08:24 AM
GhostAccord's Avatar
Remove lines = 5-10min (If you have a line/flare nut wrench)
Remove MC = 5-10 min
Replace MC = 5-10 min
Replace lines = 5-10 min
Bleed Break lines = 30 min
The most time consuming part of the job will be bleeding the brakes. A job like this you should be able to do within an 1hr, 2hrs max.
Place you may run into problems is if you do not have a flare nut wrench. If you only have a standard open end wench I would suggest soaking the fittings with WD-40/PB blaster and then hitting them with with a torch for 30 sec. Crack the fittings after heating them. Loosen them a few turns but do not fully remove them until they have cooled.
Old Jun 22, 2008 | 08:29 AM
hondapunkrock's Avatar
Default Re: Replacing brake master cylinder (GhostAccord)
guess the slave cylinder would be about same process? anyone know where its at on a 90 accord 4 door?
Old Jun 22, 2008 | 08:55 AM
ap716's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerophase &raquo;</TD></TR><TR><TD CLASS="quote">So I did a search and couldn't find anything on this topic.
I need to replace my master cylinder (94 lx) and I was wondering if anyone how hard of a job is it to do with the help of a friend and how long should it take us?</TD></TR></TABLE>
http://www.autozone.com/az/cds...s.htm
Old Jun 22, 2008 | 08:14 PM
Zerophase's Avatar
Default Re: Replacing brake master cylinder (ap716)
Thanks for the link.
Old Jun 23, 2008 | 07:52 AM
guymontag's Avatar
GhostAccord is spot-on. I did the job myself, with the correct wrench, and it was easy. The hardest part was bench-bleeding the MC, and that wasn't hard, just sorta irritating. I had my dad help me bleed the brake lines, but I probably coulda done the entire job myself. With a friend's help, you'll be golden. Get the flare-nut wrench though. You'll hate yourself if you round off those nuts on the brake lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">Remove lines = 5-10min (If you have a line/flare nut wrench)
Place you may run into problems is if you do not have a flare nut wrench. If you only have a standard open end wench I would suggest soaking the fittings with WD-40/PB blaster and then hitting them with with a torch for 30 sec. Crack the fittings after heating them. Loosen them a few turns but do not fully remove them until they have cooled.</TD></TR></TABLE>
Old Jun 24, 2008 | 04:02 AM
Hobbs94's Avatar
Default Re: Replacing brake master cylinder (guymontag)
it is a pretty easy task just make sure u bench blead the master. it will make leading the brakes after u put it on so much easier.
callmetree19
Nov 16, 2008 02:47 AM
414teg95ls
Jan 17, 2008 08:11 PM
CNSK
Jul 24, 2007 05:58 AM
mixmastabob
Dec 7, 2006 12:09 PM
Supra
Jul 6, 2005 08:48 PM
