Master cylinder replacement
Old Jan 15, 2008 | 03:08 PM
414teg95ls's Avatar
Default Master cylinder replacement
i need to replace my master cylinder on my dc4 can anyone get me some instructions on how to do this or get me some picture instructions let me know by friday before 9 PM thank you
Old Jan 15, 2008 | 03:18 PM
denraweb's Avatar
Default Re: Master cylinder replacement (414teg95ls)
It's quite easy. I believe there are two nuts holding the master cylinder to the firewall and two bolts, you need to remove those as well as the hose and hard line using a flare nut wrench. I think it's a 10mm, but not sure. Be prepared to have fluid pouring out, so keep some towels near by. Once you get those out, just replace with the new one. If you bought one without a reservoir, just clean your old one, and reuse it. Replace, making sure the hard lines and hose are secure, and place the rod for the brake pedal where it goes, and tighten the two nuts down. Refill your reservoir and bleed your brakes, and you should be set.
Not the best instructions, but it's a pretty straight forward job. Good luck!
Old Jan 15, 2008 | 03:51 PM
414teg95ls's Avatar
Default Re: Master cylinder replacement (denraweb)
thanks i need to replace all the problems ebfore i can start upgrading ya know no point in upgrading if theirs sitll problems but thanks a lot im hoping ot have my teg done by next winter a full ybuilt boosted ls teg haha hehe .70 trim turbo ahhh yes beuaitful
Old Jan 17, 2008 | 07:25 PM
SEATownboi08's Avatar
Make sure you get the right master cylinder there is a difference between abs and non abs.. One will fit and other wont. After you take it out. Bench bleed the new one out of the car to help get all air out so when you put it in less bleeding. Start in the back passenger side and get a buddy to help you out. One pump brake and hold and another to open and close the valve. Dont let pedal hit the floor. Takes alot of fluid threw2 get it done, but dont short yourself. GL
Old Jan 17, 2008 | 08:11 PM
414teg95ls's Avatar
Default Re: Master cylinder replacement (SEATownboi08)
thank yo all it fixed the problem on to my next one with power steering lol be sure to look for the thread haha
cpthaegdon
Jul 20, 2011 11:12 PM
93sivtec
Dec 23, 2007 08:17 AM
xtremehawn
Dec 11, 2007 01:53 PM
yz125rider21
20
Mar 4, 2007 12:58 PM
importfanatic17
Jan 2, 2007 02:31 PM
