hatchback spoiler removal
Old Jun 7, 2008 | 05:48 AM
billybobharris's Avatar
Default hatchback spoiler removal
Can anyone tell me how to remove (without breaking) the rear spoiler on a 92 civic hatchback. I need to seal a leak and I dont want to trash it.
Thanks in advance
Old Jun 7, 2008 | 10:16 AM
BlueIntegraBoy's Avatar
Default Re: hatchback spoiler removal (billybobharris)
Open the hatch, unplug the 3rd brake light wire, remove the acorn nuts.
Old Jun 7, 2008 | 10:21 AM
instructor74's Avatar
where is your water leak? I did a right up on fixing it a little bit ago with photos. Here you go its got everything I did to seal the leak up in my hatch.
https://honda-tech.com/zerothread?id=2222273
ps one thing that I did find out some of the cracks in the seam sealer did not sow up unless it was really cold out. So I did have to do a little more work up in the rain ch to get everything water tight
Modified by instructor74 at 11:27 AM 6/7/2008
Old Jun 7, 2008 | 10:51 AM
Default Re: hatchback spoiler removal (instructor74)
I have been working on sealing this thing up for about 2 months now off and on. Starting to really **** me off. At first I thought it was the rear hatch weather stripping. I re-glued the gasket and sealed the electrical boots in the upper drip rail. Also found a crack in the rain channel above the LR taillight and sealed that up. Still got lots of water in heavy rain. Stuck my buddy inside of it one night sprayed it with a hose and figured out most of it was coming from behind the drivers side tail light! It had been tapped there in the past and it split the seam between the 1/4 panel and the rear valance. Fixed that and assumed everything was good until the next rain. Getting light water around the top of the rear window now. I am down to the hinge mounts and the seals thru the rear glass. I wanted to pop the spoiler so I could seal the rubber gaskets and go from there. Its been a struggle but its starting to get sealed up. I am down to a cup of water after a rain instead of a gallon or two. Thanks for the feedback and good post. I will update after the next try .
goofyej6
Oct 20, 2004 08:48 AM
joshmarlette
Oct 20, 2003 05:10 PM
Si_Allen
Apr 29, 2003 12:19 PM
tommyboy
Jan 28, 2003 07:41 PM
EgSick
Jan 5, 2003 11:26 AM
