Squeeking hatch...
Old Oct 18, 2003 | 11:35 AM
joshmarlette's Avatar
Default Squeeking hatch...
OK I searched for a topic on this with no luck. Whenever I am driving, sometimes I get this wierd squeeking noise coming from the hatch. I have heard of other people with this problem, anyone know what it is and how to fix it?
Old Oct 18, 2003 | 04:35 PM
FlaN.'s Avatar
All i can say is get used to it, it's one of the flaws of the integra. I know there has to be something out there to fix that, but i've gotten used to it now.
Old Oct 18, 2003 | 05:03 PM
Bubb Rubb's Avatar
Default Re: Squeeking hatch... (joshmarlette)
WD-40?? LOL I think WD-40 has professional application in ANYTHING
Old Oct 18, 2003 | 07:01 PM
216.226.142.95:27016's Avatar
try wrapping the hatch latch piece with some electrical tape.
Old Oct 19, 2003 | 07:41 AM
Default Re: Squeeking hatch... (216.226.142.95:27016)
I'll try that, thanks guys.
Old Oct 19, 2003 | 08:18 AM
3 plus 1's Avatar
Mine turned out to be the spoiler. There is a little rubber gasket in-between the spoiler and the hatch. It wore away and allowed the spoiler to vibrate on bumps. That transmitted inside as squeeking.
Old Oct 19, 2003 | 08:26 AM
Vinny Chase's Avatar
Default Re: (3 plus 1)
I had the same problem, take the plastic off of the hatchback latch part, then I think you need to unscrew a couple screws to get the actual latch out a little bit, then wipe it down a little and spray it with WD-40, reassemble, and there should be no squeak
Old Oct 19, 2003 | 09:02 AM
markv's Avatar
my trunk does that too on my 91 integra
Old Oct 20, 2003 | 05:10 PM
fubar's Avatar
Default Re: (Vince10984)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince10984 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem, take the plastic off of the hatchback latch part, then I think you need to unscrew a couple screws to get the actual latch out a little bit, then wipe it down a little and spray it with WD-40, reassemble, and there should be no squeak</TD></TR></TABLE>
Which part(s) are you spraying with the WD-40?
I'll probably give this a try...I tired the electrical tape around the latch and that didn't quite solve the problem.
02ep3
13
Jan 20, 2006 03:11 AM
rough_draft
Jul 10, 2004 03:20 PM
hYbRiD EeEkAy
Dec 4, 2003 04:56 AM
spoonef
Aug 3, 2003 12:25 PM
integ22
Mar 4, 2003 07:48 AM
