Hit a big rock in the road, now steering wheels is crooked..
Old Jun 6, 2008 | 07:17 PM
kaluwa3's Avatar
Default Hit a big rock in the road, now steering wheel is crooked..
I'm posting this for a friend.
The car is a 00 Hatch.. He was going through a construction zone and hit a pretty big "rock" in the road. Now the steering wheel is a bit turned and not straight, but the car doesn't pull either way. Could it be alignment? Bent rack?
Thanks
Modified by kaluwa3 at 11:29 PM 6/6/2008
Old Jun 6, 2008 | 07:23 PM
elektronsi's Avatar
Default Re: Hit a big rock in the road, now steering wheel is crooked.. (kaluwa3)
check the sway bar/ tie rod ends/ lca etc, to check for damage, and definately get it alligned,
cycopath's Avatar
* B A N N E D *
Just get it aligned, they will unhook suspension from sterring wheel, straighten wheel, and hook them back up. and Aligned of course.
Old Jun 6, 2008 | 07:24 PM
lsvtec-crx's Avatar
could be alignment but more than likely it is a bent lower arm.hope for the best lets hope it is the alignment get it checked soon.
Old Jun 6, 2008 | 08:25 PM
Froth's Avatar
Default Re: Hit a big rock in the road, now steering wheel is crooked.. (cycopath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycopath &raquo;</TD></TR><TR><TD CLASS="quote">Just get it aligned, they will unhook suspension from sterring wheel, straighten wheel, and hook them back up. and Aligned of course.</TD></TR></TABLE>
*Slap Forehead* You honestly have NO idea how an alignment is performed. *Sigh*
O.P. - Get it aligned at a reputable shop. Any competent, or even half competent alignment tech can pinpoint a bent suspension component using both the alignment specs and well...his eyes. That should take care of everything.
-Froth
Old Jun 6, 2008 | 08:31 PM
civicdelsol33's Avatar
Either a tie rod or the LCA. x2 for taking it to a shop and saying u need it aligned. Then they will be like well we need to fix this before we canalign it, and they will charge u a thousand dollars and u will be broke. Me I would DIY for 50 then pay some1 50 to get aligned.
TOO MUCH TORQUE
Suspension & Brakes
14
May 20, 2009 03:42 PM
ForceFed Motorsports
Apr 18, 2006 06:55 AM
jaycetan
17
Mar 26, 2005 11:19 AM
trooper0641
18
Dec 25, 2003 05:26 PM
98slvrcx
Nov 30, 2002 11:36 PM
