~~HELP! Do I need this part? or can I do with out?? in LS-vtec Turbo
*Sorry I don't know the name of the parts.
I don't know if not having that little "part" in there will mess up the oil distribution? Can anyone help? Will it work with out it? Do I need that part... if so where can I get it? (and what does it look like?)
This is off a b16 head. Will be used in ls vtec turbo set.
Here are some pics:
Thanks for taking the time to help me!
Here are some pics:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">yes you need it.
you get it from the dealership.
looks like a dowell pin and an o-ring.
good luck</TD></TR></TABLE>
Cool. Thank you for the info.
Would anybody out there know the product number on that? I went to a Honda dealership and they told me I had to buy the whole head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG B16 »</TD></TR><TR><TD CLASS="quote">Are you sure that piece isnt still in the head? It usually stays there when u pull the caps off.</TD></TR></TABLE>
I wish, but a buddy noticed it was gone well after I got it back from getting a valve job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden »</TD></TR><TR><TD CLASS="quote">PIN, DOWEL (8X10) 90701-679-000
O-RING (8.8x1.9) 91302-GE0-000
Thanks!!!
Thanks!!!
looks like the cam cap #3. the dowel/oil ring. yes you need it. i believe that supplies the oil for your vtec. without it vtec may not work..
yes you need.
fyi, you can use an upper o ring from a fuel injector as the o ring around the dowel. ive been doing it for years
are the o-ring and dowel needed for a gsr (p72) head as well ?
so there's an o-ring for each oil orifice pin on the cam gear side, one under cam cap #3 and one in the center oil feed in the block .. any more ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1A4 »</TD></TR><TR><TD CLASS="quote">
Don't you just want to b!tch slap some of the people at the parts counter at dealerships.
</TD></TR></TABLE>Don't you just want to b!tch slap some of the people at the parts counter at dealerships.
2stockrocketz
Feb 28, 2004 07:01 PM
