compession and leakage test result..need some advice
Old Jun 6, 2008 | 06:14 PM
vteclife's Avatar
Default compession and leakage test result..need some advice
hey i juss hab quick question about compression and leakage test..
basically i hab 124,xxx miles on 98lude and i got 180lb on all 4cylinder and for leakage: 1. 10% 2. 30% 3. 20% 4. 70% <<little weird dat i made 180 with huge leak down.
70LEAKAGE on 4th cylinder...im plannin on boostin but as you can see(a terrible leak down test), i couldnt boost on dis motor..i still havent found out where is leaking from,,few problems: my engine oil is either leaking or burning fast despite the fact that i had 1000mile+ before oil chage, my engine was almost empty. and ofcourse air leaks too. i hab feeling about piston rings which i dont know squat about...any advice will help thx
Old Jun 6, 2008 | 08:44 PM
lude98SH's Avatar
Default Re: compession and leakage test result..need some advice (vteclife)
wow... are you sure your valves were closed all the way ? What air pressure did u run it at ? I think your normaly supposed to run around 90 or so. 100 at most.
What kind of compression did it make ?
Old Jun 6, 2008 | 08:54 PM
Acidcrakker's Avatar
Default Re: compession and leakage test result..need some advice (lude98SH)
He said 180 on all 4 cylinders.
So thats super odd
Old Jun 6, 2008 | 08:58 PM
lude98SH's Avatar
Default Re: compession and leakage test result..need some advice (Acidcrakker)
oo ok he said something about lbs in there too which has nothing to do with compression, its usually measured in either Kpa or PSI. But i know what he meant. That is very strange. Do you have the break down of all the compression numbers ?
Old Jun 7, 2008 | 04:27 AM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">oo ok he said something about lbs in there too which has nothing to do with compression, its usually measured in either Kpa or PSI. But i know what he meant. That is very strange. Do you have the break down of all the compression numbers ? </TD></TR></TABLE>
PSI = pounds per square inch
when you do the leakdown on that bad cylinder, can you hear air rushing back into the intake manifold?
Old Jun 7, 2008 | 07:50 AM
JasonST's Avatar
Default Re: compession and leakage test result..need some advice (bluedlude)
It sounds like u didn't check each cylinder at TDC cause if u got 180 psi for all 4 cylinders I doubt u got those leakdown numbers.
Old Jun 7, 2008 | 09:12 AM
117's Avatar
117
A leak down should run at 100 PSI. You can run it lower, but it just makes the math a little more difficult.
I find it more strange that the leaks are multiples of 10. Usually you can get a lot more accurate with leak down numbers than that. e.g. my track car has 2%, 1%, 2%, 4% leak figures on a hot engine.
Also, the engine was at operating temp right?
Old Jun 7, 2008 | 09:13 AM
117's Avatar
117
Default Re: compession and leakage test result..need some advice (JasonST)
If you're not very close to TDC when doing a leak down, the air pressure will push the piston downward and spin the crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like u didn't check each cylinder at TDC cause if u got 180 psi for all 4 cylinders I doubt u got those leakdown numbers.</TD></TR></TABLE>
Old Jun 7, 2008 | 02:21 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">
Umm yea.......
dE.fUsEd
Apr 3, 2012 08:58 AM
Tysnet
25
Sep 26, 2011 06:55 PM
Prudz_lude
Dec 1, 2009 04:51 PM
Sport_Injected
Aug 16, 2004 09:06 PM
Propulsion
Jun 5, 2002 11:48 PM
