96 gsr w/ JDM 4-1 ITR header, what catback?
As the title says. I know that the gsr header is shorter, but what kind of catback will be a bolt on without modification to a gsr motor with a type r header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboy204 »</TD></TR><TR><TD CLASS="quote">As the title says. I know that the gsr header is shorter, but what kind of catback will be a bolt on without modification to a gsr motor with a type r header? </TD></TR></TABLE>
I just did header/cat/exhaust on a 96 gsr, and you will probably have to do some modification somewhere. The 4-1 header is longer than stock gsr. If you get everything to fit with no modification you had better luck than i did.
import810
Sep 17, 2005 07:26 PM
