Gears grind
Old Jun 6, 2008 | 03:24 PM
nuke08dog's Avatar
Default Gears grind
I recently bought a 4th gen prelude si. The engine is H23a1 and so is the transmission I guess. All the gears grind a little when they are engaged. I was planning on swapping out the whole drive-train for the h22a, but am not sure I'm going to do that. So, my question is why is it grinding and can I swap the Si transmission out for the V-tech?
Old Jun 14, 2008 | 06:30 AM
ls98hatch's Avatar
Default Re: Gears grind (nuke08dog)
hey try changing out the trans fluid but use honda manual trans fluid if that doesnt work use gm syncro mesh i heard that does wonders for honda transmission yea cause sounds to me that you 2 change the trans fluid
Old Jun 14, 2008 | 07:47 PM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls98hatch &raquo;</TD></TR><TR><TD CLASS="quote">hey try changing out the trans fluid but use honda manual trans fluid if that doesnt work use gm syncro mesh i heard that does wonders for honda transmission yea cause sounds to me that you 2 change the trans fluid </TD></TR></TABLE>
common mistake, gm syncromesh isnt what you are thinking of, the "miracle" fluid is GM Friciton Modfied Syncromesh.
Go to your GM dealership and buy friciton modified syncromesh, use it for a while then change back to Honda MTF.
Old Jun 15, 2008 | 04:52 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuke08dog &raquo;</TD></TR><TR><TD CLASS="quote">I recently bought a 4th gen prelude si. The engine is H23a1 and so is the transmission I guess. All the gears grind a little when they are engaged. I was planning on swapping out the whole drive-train for the h22a, but am not sure I'm going to do that. So, my question is why is it grinding and can I swap the Si transmission out for the V-tech?</TD></TR></TABLE>
is your clutch fluid res full ? Have your tried bleeding the clutch ? Is the slave cylinder leaking ? Is it working properly ?
Does your clutch slip at all ?
Old Jun 16, 2008 | 08:23 PM
jabarty's Avatar
it's VTEC!!! not the phone company lol
singher01
Jul 25, 2008 10:19 AM
sdr85
Sep 24, 2007 12:39 AM
Lude S
Jun 11, 2005 02:10 AM
accordinglyevil
Aug 5, 2004 11:46 AM
SLOAZZ95
Sep 3, 2003 06:52 AM
