Whats the proper gapping of my spark plugs for a 92 civic dx?
What should I gap my spark plugs to? Whats recommended? Sometimes when I start my car it sounds like all 4 cylinders are not firing up at the same time.
stock 92 civic DX with ONLY 91k!!!, changed the ignitor, plugs, wires, cap, rotor....fuel filter, main relay....WTF?
1 month ago when i changed the fuel filter, started the car 10 times straight and was fine, couple days later it started acting up again.
Then I changed the relay... did the exact same thing. Started up fine for days and then started fing up again.
I changed all above other things beforehand.
the only CEL I have ever has is #17 for VSS.(Fixed).... Never had a misfire read. Car has been babied forever.
Maybe the fuel pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krisfnbs »</TD></TR><TR><TD CLASS="quote">What should I gap my spark plugs to? Whats recommended? Sometimes when I start my car it sounds like all 4 cylinders are not firing up at the same time.
stock 92 civic DX with ONLY 91k!!!, changed the ignitor, plugs, wires, cap, rotor....fuel filter, main relay....WTF?</TD></TR></TABLE>
^sounds to me like you need a new timing belt. we all have been there at one point in our honda life. its about your time.
I have purchased all necessary items to do a timing belt change(waterpump, and the gaskets, with the other belts)... Just havent had a chance for my friend to put it in.
Wouldthis cause my car to stutter when starting though??
bad timing causes many things. one of them being a stuttered start. it also decreases mpg's, loses performance, sucks altogether... you get the point. you should have your timing belt done now in your cars life. i think honda recommends it at either 90 or 100k. not sure which. basic tune-up you already did so go with what honda says you should do.
yeah I need to get all that in asap. My Mechanic I had do my other timing/waterpump job for $150 on the side lives 60 miles away and is always busy....errr
fastfed
26
Jul 5, 2004 10:39 PM
