92 civic no spark
92 civic no spark
i have a 92 honda civic with a 1.5 it wont start i have no spark i put new plugs and whiers and a new coil and i have replaced the ignitor.still no spark what wood b my problem? i am at my end with it have spent days trying to figer it out
Re: 92 civic no spark
Try getting a new distributor that might be the cause you get no spark
dizzy, main relay or even ECU's can be the culprit. It's more than likely the dizzy or even bad plugs, have you stuck a screwdriver in the spark plug cap to see if it's arcing? That's how i do it to make sure it's the wires/dizzy and not the plugs. Also, listen in to see if you can hear your fuel pump kick on and your main relay click 3 times. If none of that happens, you need a new main relay, the EG civic's are infamous for the main relays going out. If all that is good, just replace your dizzy OR check to make sure the ground on your thermostat didn't become loose some how....well, i think i covered everything.
Noo_Ish_mee
11
07-13-2009 09:47 AM
akdmks1326
11-06-2005 08:16 PM
