Help With Leak??!!
I have bad water leak comin from somewhere! When it rains and I go out, my floor and my whole trunk gets drenched in water. Please help if you got any tips what to look for!
the one on the floor board comes from the hole where the outside air comes inside the car, take off the blower close the doors and get a flash light and ask somebody to spay some water on the car, you should be able to find it and seal it.
if you have a steamer blow type of deal can spot the problem. Close your trunk, use the steamer in the inside then you will be able to spot the problem from the outside. If you don't have a steamer then start smoking your weed.
91EFCIVICII
Feb 28, 2011 11:56 AM
