Help With Leak??!!
Old Jun 5, 2008 | 06:56 PM
Jizzo's Avatar
Default Help With Leak??!!
I have bad water leak comin from somewhere! When it rains and I go out, my floor and my whole trunk gets drenched in water. Please help if you got any tips what to look for!
Old Jun 6, 2008 | 02:42 PM
4crx4me's Avatar
Default Re: Help With Leak??!! (Jizzo)
You could try searching, but oh well, Im here now. Spoiler center mounting bolts? I just did mine this afternoon. Taillight gaskets?
Old Jun 6, 2008 | 02:50 PM
95_B18b1_Teg's Avatar
wing holes
try seeing if your weather strip is cracked or gone
Old Jun 7, 2008 | 01:46 PM
God-Driven's Avatar
the one on the floor board comes from the hole where the outside air comes inside the car, take off the blower close the doors and get a flash light and ask somebody to spay some water on the car, you should be able to find it and seal it.
Old Jun 7, 2008 | 01:55 PM
REAL TIME's Avatar
Default Re: (God-Driven)
if you have a steamer blow type of deal can spot the problem. Close your trunk, use the steamer in the inside then you will be able to spot the problem from the outside. If you don't have a steamer then start smoking your weed.
Old Jun 8, 2008 | 09:29 PM
13loody's Avatar
If you have a moon/sunroof, check the drain tube.
beat
Jun 11, 2014 11:04 AM
91EFCIVICII
Feb 28, 2011 11:56 AM
jaebekae
Feb 27, 2010 02:02 PM
airikkCRX
Jan 21, 2010 09:10 AM
Wiseguy619
Nov 11, 2006 03:49 PM
