HOW TO: Fix Parking Lot Scuffs
Old Jun 5, 2008 | 06:31 PM
crazyimport's Avatar
Default HOW TO: Fix Parking Lot Scuffs
Well some DONK hit my girl friends car in an ikea parking lot on the weekend.
And working in a Toyota plant paint booth all day i have a bit of experience in dealing with this.
Also save you a few bucks at the body shop
So i thought i would write a how to up!
TOOLS NEEDED:
Compressor (or electric buffer)
3M Polisher
3M FINESSE POLISH - EXTRA FINE
3M WOOL PADS
3M Orange Waffle Sponge
2000 GRIT WETSAND PAPER
Acetone
WRITE UP
This is what im starting with.
From the idiot that hit the car in the parking lot. Its located on the rear 1/4 which is steel. If it was the rear bumper it might not have been salagable since plastic gouges alot easier
1)Whipe the area down good with your acetone on a rag and get rid of all the paint from the other vehicle and dirt
2)Take a block sander with your 2000 grit and wet it in some water or put water on the area you would like to fix
3)Start sanding the area lightly in a circle motion keeping the paper wet. MAKE SURE YOU DO NOT HAVE ANY DEBRIS ON YOUR PAPER OR IT WILL SCRATCH THE CLEAR COAT!
4) Make sure you do not sand too much and go threw the clear coat or you will have to recoat the area. Sand in small steps rather then big ones
5)Put the polish on the wool pad on your buffer and buff the area which you sanded.
( Do not press on the buffer let it do its own thing, pressure is not needed)
6)Keep Poling the area until all haze is gone. Make sure you look at the area from meny areas
7)If your using a dark colour such as black or a monocolour(usually the light red colour) (monocolour=no clear coat) then your probably going to have to use a foam pad to get rid of the haze. Put some polish on the pad and buff away until the haze is gone
The Final Product
As you can see there is still a small dent and paint chip there.
Hopefully soon i can cover on how to do small dent repairs and flash chipped area
Hopefully i saved you a few bucks!
thanks for your time
Crazyimport
Old Jun 5, 2008 | 06:33 PM
95BoostedEJ1's Avatar
damn nice job
Old Jun 5, 2008 | 06:44 PM
teamsol's Avatar
Default Re: (95BoostedEJ1)
good how to
Old Jun 5, 2008 | 10:34 PM
Mingo's Avatar
Default Re: (teamsol)
nice job
Old Jun 5, 2008 | 10:45 PM
hushypushy's Avatar
Looks great. Spend the insurance money on something else
rayray NOT shanaynay's Avatar
Default Re: (Mingo)
very nice write up!
Old Jun 6, 2008 | 01:58 AM
cyb3rjak's Avatar
Default Re: (rayray NOT shanaynay)
good **** too bad that only works if u still have paint left! lol -=X
Old Jun 6, 2008 | 10:32 PM
VNY_Khmer's Avatar
Default Re: (cyb3rjak)
clean job right there
Old Jun 7, 2008 | 12:05 AM
HBK GABE's Avatar
Default Re: (VNY_Khmer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNY_Khmer &raquo;</TD></TR><TR><TD CLASS="quote">clean job right there </TD></TR></TABLE>
Old Jun 7, 2008 | 01:28 AM
alltech.magoo's Avatar
Default Re:
nice write up
Old Jun 7, 2008 | 11:59 AM
JALOP B16's Avatar
Default Re: Re: (alltech.magoo)
That came out good.
Old Jun 7, 2008 | 01:40 PM
poopsquaddle's Avatar
SHG_Riley
Appearance Build Threads
1490
Feb 11, 2009 09:00 AM
Mikebdagr8
Paint and Body
Apr 14, 2008 05:21 AM
Zappythebum
Oct 9, 2007 10:28 PM
phatboycrxhf
Welding / Fabrication
Jun 3, 2007 11:44 AM
tegon-gsr
Feb 27, 2005 07:19 PM
