oil presure is low!!!!!!!
Old Jun 5, 2008 | 05:57 PM
mcaro's Avatar
Default oil presure is low!!!!!!!
To make a long story short my oil pressure was really low and the v-tech was not working.The gauge reads 5psi. I took the valve cover and cam caps off to make sure the O-ring was on the 3rd cyclinder cap. Well it wasnt, so we now know what the problem is, so i thought! untill my buddy shows me that there is a bolt thats under the intake cam by the dizzy thats missing. Come to find out that bolt holds the oil pressure and i could have blown my motor. Does anyone know what size that bolt is, or can i just put any type of bolt there?
Old Jun 5, 2008 | 06:24 PM
inspyral's Avatar
Can you point out where this bolt is in this diagram?
Old Jun 5, 2008 | 07:04 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (inspyral)
you talking about the plug??? it's 1/8 NPT plug....if that was out you would have spit oil ALL over the ground on initial startup
Old Jun 6, 2008 | 04:05 AM
mmuller's Avatar
Mad Scientist
Default Re: (Evs-One)
there is also internal plugs, try adding the plug to see what happens
1/8 BSPT
Old Jun 6, 2008 | 06:39 AM
mcaro's Avatar
Default Re: (mmuller)
ok if you take the dizzy of and look into the head right under the intake cam there is a hex bolt that holds the oil pressure, well that hex bolt is not there.
Old Jun 6, 2008 | 02:30 PM
mmuller's Avatar
Mad Scientist
Default Re: (mcaro)
thats right get a plug and put it in there
make SURE it is 1/8 BSPT
that plug leads to vtec oil gallery, mostly your reason for low oil pressure seems to be the missing o-ring and restrictor
boostmee
Aug 18, 2008 02:05 PM
EKISTHENAME
Apr 20, 2006 08:11 AM
eg crunkmonster
Feb 3, 2004 08:47 PM
crx1856
Sep 19, 2003 09:11 AM
VTgringo
Jun 30, 2003 07:36 PM
