oil pressure switch question
Old Jul 16, 2002 | 05:47 PM
civbeater90's Avatar
Default oil pressure switch question
if you pull the switch out should i be able to see into the block?reason i ask is i had the block worked on at a shop and i t lookslike a piece of wax is in there.maybe it was put in there when they hot tanked?can anyone help me on this??
Old Jul 16, 2002 | 05:59 PM
BreakStuff's Avatar
New User
Default Re: oil pressure switch question (civbeater90)
the oil pressure switch is less than an inch in diameter and isn't going to give you a good visual point for inspecting the internals of the block.. how about doing an oil change and or coolant flush to see what kinda crud comes out..
Old Jul 16, 2002 | 06:02 PM
Default Re: oil pressure switch question (BreakStuff)
ok let me clear things up.the motor is a fresh rebuild.the only crud that is int here is probably gon abe from honing etc.all i know the whole i stiny i just need t oknow if it is supposed to be clear or have anything inside of it?
Old Jul 16, 2002 | 06:11 PM
BreakStuff's Avatar
New User
The oil switch port should be clear and have no blockage or restriction.. but some buildup might be considered normal..
Old Jul 16, 2002 | 06:27 PM
ok thanks.i think i will just try to dig the rest of it out.i really just think they stuck something in there to keep it clear and forgot to pull i out.
mutiny93
Dec 9, 2011 07:54 PM
DA_9
Jan 8, 2008 10:16 AM
RaCk
Jan 4, 2006 12:28 PM
