eg head swap, now makes no power!
i was misinformed that my head gasket was blown. so i planned puttin a new one on when i found an auction on ebay for a p&p head with port matched intake manifold. my motor is a d16z6.
well i got everything together, adjusted the valves, set the idle, and swapped oil and water.
now the thing makes NO power on the bottom end and barely any up top. i have absolutely no idea why.
all hoses are right, the head is torqued to spec, and all new genuine honda gaskets were used.
i have no cel either
if anybody has any ideas, some input would be amazing.
thanks guys and gals
Check your cam timing.
I am willing to bet that your engine doesn't rev worth crap either
I am willing to bet it's off.
Also check your ignition timing, besure to use the service connector jumper to check your timing to dissable the advance.
On the D16Z6 you need to have the crank set at TDC
and the cam gear needs to have the "up" up... and the mark on the cam gear at around 7 o'clock needs to line up with the arrow on the plastic cover on the head
the two indented lines DO NOT line up flat against the deck of the head, it is supposed to be a little more count-clockwise.
see the manual:
http://www.redpepperracing.com....html
see the manual:
when i put the head on, i just spun the motor til piston 1 was up top, than spun the cam til the up was up and the indents lined up. the belt fit on fine.
i dont know how to time the ignition, and i cant find a good writeup about it.
thanks alot for your help, it was very informative.
and it doesnt rev too well, it feels as if theres no throttle response, and i have to rev it to about 2500 to take off without stalling.
Here is a write up in ignition timing.
http://www.c-speedracing.com/h...g.php
If this doesn't do anything... than you will need to check your cam timing.
here is the diagram for the D16z6
http://www.rr-ax.com/bbs/photo...=1224
Modified by Crazydave at 9:41 AM 6/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axegrinder87 »</TD></TR><TR><TD CLASS="quote">when i put the head on, i just spun the motor til piston 1 was up top, than spun the cam til the up was up and the indents lined up. the belt fit on fine.
and it doesnt rev too well, it feels as if theres no throttle response, and i have to rev it to about 2500 to take off without stalling. </TD></TR></TABLE>
FYI the belt will fit on fine no matter where you have the cam set.
which indents were lined up to what?
There are 3 indent markers.
the two indent markers at 3:00 and 9:00 are slightly off level.
the indent marker at around 7:00 should point directly to the mark on the plastic cover.
i cant thank you guys enough for all the help.
i bought a timing light, learned how to time the ignition.
thanks crazydave for all the links on cam timing.
turns out the cam was off a tooth.
everythings running great.
again, thank you all so much
daboy155
Jun 3, 2018 11:57 AM
splitime
Aug 19, 2002 02:46 AM
