b16 crx heater core
hi i took out my heater core from my crx and need to know what to do with the to hose that out of it and connect to the block some one told me to just plug of the to holes and some else said to conect the to hoses together what should i do ???
why u taking out the core? leaking? I would just route the hoses back into each other get like a 180 deg and run them into each other, what i did with my truck till i got a new core,, easy fix till it gets cold but i guess it doesnt get to cold over there
i took it out for my wire tuck. so you pluged yours bryan does affect your coolant flow would it over heat i rather just plug it to save more space any thoughts
you can block them off or just couple them together. when temp control in the car is on cold, it's effectively blocked at those hoses anyway.
i would just connect them so i could get a little coolant capacity/flow and so i could use the heater core again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsveeee »</TD></TR><TR><TD CLASS="quote">i took it out for my wire tuck. so you pluged yours bryan does affect your coolant flow would it over heat i rather just plug it to save more space any thoughts </TD></TR></TABLE>
yups i plugged mines...my car never did over heat ever. it just looks cleaner in a way because there are less hoses to deal with. i doesn't effect the coolant flow in any way.
Jeff Lebowski
Nov 14, 2016 05:02 PM
atikovi
Oct 7, 2010 05:49 PM
