Larger Injector question
Old Jun 4, 2008 | 11:16 PM
Prudz_lude's Avatar
Default Larger Injector question
Prepare yourself for some noob questions
I can get a set of rc 650cc injectors right now. Should be pushing 190whp-200whp on the motor and about 280whp on nitrous. My question is it ok to run such large injectors with this setup? will i constantly be flooding my engine with fuel by running them? I have a hondata s200, can i tune my injectors to use less fuel when not spraying and more when spraying? Suggestions of what size i should be using? Like i said, i can get them for a really really good price in my city which is why i need to know.
Old Jun 5, 2008 | 05:35 AM
smokedyou19's Avatar
Default Re: Larger Injector question (Prudz_lude)
Can you get rc 550 injectors for cheap? I would go with that size
Old Jun 5, 2008 | 06:08 AM
Acidcrakker's Avatar
Default Re: Larger Injector question (smokedyou19)
They both sound way to large to me. You can run larger injectors but you are going to have tune.
I have slightly larger injectors on my lude but they are only 370cc.
Old Jun 5, 2008 | 06:30 AM
ImPuLsIvE's Avatar
they're too big, but a good tune should balance things out.
600cc+ injectors are usually for people running turbo.
Old Jun 5, 2008 | 09:34 AM
Prudz_lude's Avatar
Default Re: (ImPuLsIvE)
Just a heads up guys i would not be running these injectors until i am on the dyno getting my car tuned for nitrous control. 550cc are not an option since i am picking these off of a friend. 650cc's are all he has.
I have seen turbo cars that have made under 300whp use this size and they have been fine. I will be making 270-280whp when spraying to i am going to need some large injectors to support the power.
They are saturated as well so that means after they are installed and tuned i can take the resistor box out as well correct?
Old Jun 5, 2008 | 10:30 AM
mattsnooz's Avatar
Default Re: (Prudz_lude)
Can't you use a "two timer" setup(not sure if you can with s200 setup as I have never seen or used one)? Its something that goes in your ecu that allows you to toggle between two programs/bins at the flick of a switch.
I'm unfamiliar with s200 but with crome and a burn1 unit as well as the two timer with a second chip, you can run two separate programs when you need it with little effort.
That might be the best solution rather than just having one all rounded bin/maps.
Than your car will run properly when not using nos, and when using nos, (ie. your going to drag) than switch to your other program.
I hope s200 can accomidate that, but as far as I know s200 is pretty much a standalone though right???
Good luck either way man.
edit* you got local tuners?? I need to go atleast an hour and a half to find a tuner in Toronto or London.
Old Jun 5, 2008 | 10:43 AM
Prudz_lude's Avatar
Default Re: (mattsnooz)
lol really? thats most likely to the insane rate for office space in Toronto. You guys have some of the highest in North America. We used to have 4 shops in Edmonton. Now i think there are 2 that have dyno's. I am actually driving 1.5 hours down to Red Deer to get my car tuned so it isn't locally that i am getting my car tuned.
I'll look into what you suggested.
Can I tune the injectors to spray more when spraying and less while DD'ing? Isn't that what happens with a turbo setup? When in boost more fuel is spraying rather than when just DD'ing?
Old Jun 5, 2008 | 11:03 AM
Prudz_lude's Avatar
ok i just spoke to my tuner. I am going to just go with some 450cc injectors. Just to make sure though, running some DSM blue top 450cc injectors can i install them and drive with them without tuning? I'll be running a aem fpr and aem fuel rail. Do i just adjust the fuel pressure on the fpr to work with the 450cc's? what pressure would i be using? Stock?
Modified by Prudz_lude at 12:09 PM 6/5/2008
Old Jun 5, 2008 | 11:22 AM
Prudz_lude's Avatar
http://cgi.ebay.ca/450CC-Injec...wItem
those are what i am looking at right now.
dE.fUsEd
Nov 24, 2011 07:29 AM
HondaKid936
Nov 13, 2008 07:16 AM
96redgsr
Jul 21, 2004 09:46 PM
EFb18b
Mar 19, 2004 01:20 PM
h22civic95coupe
Jun 29, 2003 09:38 AM
