rust on cylinder walls
Old Jun 4, 2008 | 07:20 PM
black0hatch's Avatar
Default rust on cylinder walls
i got a ls block that was honed and cleaned then sat in my garage forever and now theres a little bit of rust on one of the cylinder walls. is that all bad? does it need to be rehoned?
Old Jun 4, 2008 | 08:03 PM
onefastek9's Avatar
Default Re: rust on cylinder walls (black0hatch)
only if you can't feel it with your figers, light rust will come off with some cleaning like using a very fine sand paper or someting of that kind. i've had motors sit for years and have little rust all I do is clean it as good as I can so I don't do damage to the rings. now unless it's very bad then you've got problems
Old Jun 5, 2008 | 02:49 AM
GhostAccord's Avatar
Default Re: rust on cylinder walls (onefastek9)
If it's rust that you can wipe off with an oil soaked rag and not see any dark pits in the walls then you should be OK. But if you wipe down the rust and see dark pits I would get a light hone to freshen up the walls.
I've never done the sandpaper trick. And honestly I wouldn't touch the insides of a machined cylinder wall with a piece of sandpaper. Wouldn't that disturb the crosshatch patterns on the cylinder walls and possibly cause a low spot. What if he puts too much pressure in one area? The thought of a guy using his hands to scuff up a cylinder wall seems a bit inconsistent to me..... But like I said I've never tried it it may be as easy as he makes it sound.
Old Jun 5, 2008 | 01:25 PM
Default Re: rust on cylinder walls (GhostAccord)
ya i dont wana touch it with sand paper. i was thinking maybe a brilow pad or a sponge to wash dishes with but use the rough side. would that be ok??
Old Jun 5, 2008 | 09:54 PM
akces's Avatar
ive sanded it down with paper, not a major thing. i still had high compression on the ones i work on.
Ser1N
Feb 15, 2013 09:14 AM
famous323
Feb 10, 2012 01:31 PM
Suck my DX
Aug 16, 2007 08:38 AM
JFG Kevin
Sep 8, 2006 07:27 PM
blazin
Nov 19, 2001 04:39 PM
