highway RPM's
i have a d16z6 engine and at 70mph i hit a little less than 3000rpm on 5th gear, does that help? But i have a dx trans, i don't know how different it will be on the si trans
Ah no worries, the 5th on the DX and Si were the same from the transmissions I've compared (I'm in market for a 5-speed swap). Should be the same, could be different depending on year of transmission, of course.
[edit to not bump old post: Right, I forgot about final drive.]
Modified by Davus at 3:23 AM 9/2/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kinfer »</TD></TR><TR><TD CLASS="quote">i have a d16z6 engine and at 70mph i hit a little less than 3000rpm on 5th gear, does that help? But i have a dx trans, i don't know how different it will be on the si trans</TD></TR></TABLE>
The Dx trans has longer gearing, you will not be doing under 3k at 70mph with and si trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus »</TD></TR><TR><TD CLASS="quote">Ah no worries, the 5th on the DX and Si were the same from the transmissions I've compared (I'm in market for a 5-speed swap). Should be the same, could be different depending on year of transmission, of course.</TD></TR></TABLE>
That doesn't mean the transmissions are the same.
Op with and si trans you should be doing about 3500-4k going 70 mph. If its gas your worried about It's not that big of a deal.
I have a y8 running on a y5 ecu with a 95 si trans and I still get 40 miles to the gallon with no spirited driving.
From: ....................................................................................................
at 65 you are crusing at 2900 to 3 grand and at 70 your just crusing at around 3100 or 3300?
DirtyD777
Feb 10, 2006 04:01 PM
civicwagonman
Oct 18, 2002 06:40 AM
