fuel gauge stays on empty after cluster swap
after cluster swap fuel gauge stays on empty sometimes when turn car ign. on slightly moves up then back down other times goes to full then after like being on a minute goes back to empty...help....crx with gsr cluster
what car is this in for staters?
and also the obd difference between years in cars can be a big issue as some wires dont go to the same place,
an easy fix is to take your original gauge cluster (assuming you have one) and swapping the green circuit film on the back to your new gauge cluster,
most of the time that will solve the issue, if it doesnt pull out your helms manual and look up troubleshooting the fuel gauge
thefiztec
Aug 7, 2013 04:29 PM
CWBETB
May 28, 2002 07:40 AM
