leaking brake line
Old Jun 4, 2008 | 04:48 PM
hastingsr's Avatar
Default leaking brake line
how much would you think this cost to get repaired? Has anyone got this repaired before.... need some advice..
Old Jun 4, 2008 | 04:57 PM
Audiojb's Avatar
Default Re: leaking brake line (hastingsr)
I redid all my brake lines and had a smal leak around the fitting, You could buy a straight line and bend and flare it? or order one from acura prebent? like 20$?
Old Jun 4, 2008 | 04:59 PM
hastingsr's Avatar
how much would it cost to take it somewere to get fixed you think
Old Jun 4, 2008 | 05:21 PM
Audiojb's Avatar
not to sure. Its not a hard fix. depends which line it is.
Old Jun 4, 2008 | 06:21 PM
hastingsr's Avatar
the leak it is close to right were it come down and goes under the car, at the begining of that plastic shroud near the cat.
Old Jun 4, 2008 | 07:49 PM
hastingsr's Avatar
there hard lines, they look pretty rusted... anyone?
Old Jun 5, 2008 | 08:10 AM
hastingsr's Avatar
anyone help?
Old Jun 5, 2008 | 08:26 AM
hatchling37's Avatar
Default Re: (hastingsr)
Are you even contemplating doing this yourself? If so, get a 10mm flare nut wrench and douse that bitch in PB blaster or some other penetrating lube and let it soak.
If you're just looking for a quote, I would guess something like between $80-$90 for the line and probably a couple hours labor to install and bleed the lines out. Plus whatever they charge you for shop supplies or whatever other bullshit they can come up with. You're probably looking at $300 or so. As opposed to $75 for a new line. It's up to you, I guess.
Old Jun 5, 2008 | 01:03 PM
hastingsr's Avatar
im looking for advice so i can decide if i wna do it myself or not sence ive never done it before, the tubes and bender is only around 20$ from advanced and they said its not too hard so ill prly go ahead and attempt it
Old Jun 5, 2008 | 04:09 PM
Dogginator's Avatar
Daisy... Daisy...
Swapping the hard line isn't too bad. Bleeding the system afterwards can be a pain.
Old Jun 5, 2008 | 04:56 PM
hastingsr's Avatar
mine are pretty rusted out and I don't know were to start, I will prolly just take it into a shop and payy 300 for them to take car of it
justinball1717
Honda Civic (2001 - 2005)
Oct 24, 2016 06:43 PM
supaman
Aug 1, 2016 05:27 AM
94CivicSi
18
Mar 28, 2008 05:03 AM
JCracer723
Mar 9, 2007 06:52 AM
turbospool
Aug 10, 2003 11:38 AM
