No ABS????
Old Jun 4, 2008 | 10:55 AM
BoBo Racing's Avatar
Default No ABS????
k the car use to have abs but i went to the jdm hubs which did not come to mount the abs sensor. so i drilled the hub and screwed in where it was on the usdm hub looks perfect and fits perfect.....i hooked up the abs lines back up and the abs light turned off went for a test drive stopped a couple of times and still worked fine as soon as i got on it the abs light turned back on im like wtf. looked at the sensor had some metal shaving from me drilling cleaned it off still on changed the acutal sensor and wire still on left it over night with the batt off abs light still on im out of ideas... does ne one have a clue or any idea of what i can do trying to solve the abs problem for expo please let me know and what can i do a bout bleeding the lines then with out abs cause i heard the abs pump will have air in the lines please need advise thanks people
Old Jun 4, 2008 | 11:41 AM
ZygSpeed's Avatar
Default Re: No ABS???? (BoBo Racing)
I had a similar issue years ago.
Apparently the gap between the sensor and the toothed ring is too big, resulting in poor sensor functionality.
I never got around to fileing down the appropriate area (most likely the seating area of the sensor) to bring it closer to the ring on the shaft.
My issues may have led to an accident that totaled the car ...
Modified by Zygspeed at 3:54 PM 6/4/2008
Old Jun 4, 2008 | 12:00 PM
Default Re: No ABS???? (Zygspeed)
so how close is it soppose to be to the ring? and what can i do about a brake flush with the abs pump still on and no abs? cause from what i hear ill have air in the pump......
Old Jun 4, 2008 | 12:13 PM
ZygSpeed's Avatar
As far as the correct spacing, I don't know since I don't remember where I put my Helms manual, but it would need to be closer.
It should still be possible to flush/bleed the brake fluid, as Steve Sakai was able to do mine with this situation and the JDM axles back when I still had my first ITR.
Other than that, I got nothing!
Good luck.
Old Jun 4, 2008 | 12:40 PM
citrus3000psi's Avatar
what code is the abs throwing?
Old Jun 4, 2008 | 12:51 PM
Default Re: (citrus3000psi)
no code just the abs light is on
Default Re: (BoBo Racing)
and would ne one know how to take the srs light off both airbags are hooked up i know a lil off topic
Old Jun 4, 2008 | 01:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing &raquo;</TD></TR><TR><TD CLASS="quote">no code just the abs light is on</TD></TR></TABLE>
Just makeing sure I'm reading this correctly. You've tried to check for the abs codes but you don't get any? Just because the CEL isn't on doesn't mean you wont get any abs codes.
Old Jun 4, 2008 | 10:20 PM
Evs-One's Avatar
Solbros Owns Me
bleeding the lines isn't going to do anything.
When you clear an ABS code/replace a part/etc, you MUST drive the car over 7mph for the light to turn off. You can replace every single ABS component in your car, but without driving, the light will never stay off.
Take your car out of the garage and see if the light shuts off
Old Jun 5, 2008 | 04:04 AM
Default Re: (Evs-One)
i have been driving it and still the abs light is on how can i erase the code then? i tought if i hooked up the sensors it would go away like it did b4 but went for a test drive and it came back on
Old Jun 5, 2008 | 01:31 PM
JOHN WAYNE's Avatar
HEY BOBO!
SEARCH!
you will find many threads on resetting your ABS and SRS lights. the SRS is kind of tricky, but i'm sure you can manage, son son!
oh, and btw...before you try to ERASE the code, you should maybe find out WAT the code is...
you do that the same way you check your CEL codes.
MikesEJ1
Mar 25, 2013 03:28 PM
josh-roy
Jul 30, 2010 02:32 AM
rollercosta123
Nov 25, 2005 12:09 AM
TerribleOne
Mar 19, 2003 10:59 AM
Mike B
Apr 17, 2002 09:36 PM
