Need help with running antenna wire
Old Jun 4, 2008 | 10:38 AM
Jooleeus's Avatar
Default Need help with running antenna wire
I recently purchased a new antenna for my hatchback, but I'm having trouble installing it. The car's antenna and wire were ripped out by a previous owner, so I can't use it as a guide to pull the new antenna's wire through the pillar. I did some searching and people have suggested using a coat hanger, but I can't figure out where the hanger is supposed to push through under the dash. Can anybody help me with this? Even a quick picture or description would be extremely helpful. Thanks!
Old Jun 4, 2008 | 10:47 AM
nsxmatt's Avatar
Default Re: Need help with running antenna wire (Jooleeus)
Just feed it through the pillar and there is a opening right under the main relay you can pull it through and feed it under the dash to the radio.
Old Jun 4, 2008 | 01:40 PM
traxxasx's Avatar
Just keep shoving it down.
Under the dask behind a flexable plastic tube for the heat/ac vent you will see a rubber covering flap cover a hole where those wires run threw.
Hope that helps/
Old Jun 4, 2008 | 03:13 PM
n3h3bkau's Avatar
If you twist it side to side as you push down it will help it navigate any obstructions that get in the way. Than just pull it through.
koumatae
Aug 2, 2012 12:53 PM
taylorgang
Oct 18, 2011 07:10 AM
r3sgtec
May 22, 2007 10:23 PM
d16efsedan
Feb 23, 2006 09:39 PM
ef-hatchcrap
12
Aug 4, 2005 11:37 AM
