Squeaky Suspension
Old Jun 4, 2008 | 10:35 AM
Tysnet's Avatar
Default Squeaky Suspension
I've tried searching for info on this but could not find anything exactly the same. I recentley replaced all the front end suspension bushings and completely rebuilt the steering rack. Now I didn't replace the shocks in the front so maybe that could be it, but anyways the problem is squeaks! Ever since I did it my whole car's suspension squeaks and creeks over bumbs, down drive-ways, and during regular driving if the road isn't newly paved or leveled. Anyone know what's up?
Old Jun 4, 2008 | 10:38 AM
draperj09's Avatar
Default Re: Squeaky Suspension (Tysnet)
a bushing
Old Jun 4, 2008 | 01:35 PM
Tyson's Avatar
how are your balljoints? if the boots are torn, old rust, dried up balljoints will squeek.
Old Jun 4, 2008 | 03:08 PM
the_prophet805's Avatar
your probably right about it being the shocks. they do tend to get noisy when they start to get worn. had the same proeblem in a couple other cars.
Old Jun 4, 2008 | 09:25 PM
traxxasx's Avatar
Did you grease all your bushing?
Old Jun 6, 2008 | 01:37 PM
Tysnet's Avatar
Default Re: Squeaky Suspension (Tyson)
Replaced the balljoints at the same time... Upper and lower
Old Jun 6, 2008 | 01:41 PM
Tysnet's Avatar
Default Re: Squeaky Suspension (the_prophet805)
ya maybe it could be the old shocks combined with all the new bushings, balljoints, cv axel's, tierod's, and the rebuilt steering rack? I don't know
Old Jun 6, 2008 | 01:44 PM
Tysnet's Avatar
Default Re: (traxxasx)
Well I greased all the bushings not already pressed in, which I thought those should have already been pre-greased. I used napa mulipurpose grease
Old Jun 6, 2008 | 02:25 PM
Tyson's Avatar
Default Re: (Tysnet)
greased what bushings? did you replace stock bushings with poly?
you shouldnt be greasing rubber bushings.
Old Jun 7, 2008 | 01:50 AM
Tysnet's Avatar
Default Re: (Tyson)
My workshop manual showed some area's that needed to be greased when replaced. I replaced, with genuine honda parts, and greased all of the stabalizer bar bushings and the radius rod bushings. Other parts I replaced, that aren't honda, and didn't do anything but install are the lower ball joint, the lower control arm bushings, and the entire upper control arm (bushings and balljoint). I didn't purchase anything poly. Everything standard rubber. I think the sound is coming from the upper control arm more than anything else. Not sure though. Any ideas?
arziffel
Jan 31, 2012 07:36 PM
Jaynik
Dec 31, 2011 08:48 AM
DreamCatcher
Jun 24, 2005 11:07 PM
jerbear!
Suspension & Brakes
Feb 9, 2005 04:10 AM
DannyITR
Jun 8, 2004 08:32 AM
