Vtec question????
Old Jun 4, 2008 | 08:14 AM
importsalltheway's Avatar
Default Vtec question????
i am building a 88 acura integra. it is bone stock with the DOHC motor. i wanna convert it to Vtec but have no idea what i need to do or what i need to get. Is there anyone that can give me somne pointers?
Old Jun 4, 2008 | 08:58 AM
Default Re: Vtec question???? (importsalltheway)
i also forgot to ask if it would just be better to take the car to Intec Racing in Kent to have them do the Vtec???? any suggestions will help
Old Jun 4, 2008 | 09:01 AM
standbackimapro's Avatar
Its an LS motor Correct? B18b?
If your converting it to vtec, youd be making it Ls/ Vtec, Ls/Vtec Setups are known to be Unreliable, and lasting only 7000 miles or so,
But As long as you have a good base, it will last long,
The main things you would need are ECU,Wiring Harness, Gsr or b16 head,
Headgasket.. and if you wanna make it last, new ARP Head studs
If you want it to be a reliable as a stock motor, id suggest the following
New OEM LS (90-01) B18a/b head gasket
New OEM valve seals
GSR ARP head studs
New GSR/ITR water pump (P72)
New GSR/ITR timing belt (P72)
New GSR/ITR/96+ Bseries oil pump (P72)
Magnetic oil drain plug (important for break in)
Old Jun 4, 2008 | 09:23 AM
gibsanez's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Its an LS motor Correct? B18b?
Terrible mis-information. ls/vtec's are not known to be any more unreliable than any other honda engine that hasn't been assembled correctly. People build ls/vtec's that have lasted upwards of over 50k.
Old Jun 4, 2008 | 09:28 AM
gibsanez's Avatar
Default Re: (gibsanez)
Plus, I just noticed you said the car is an 88, meaning you don't even have a B series in it right now, if unless it's swapped.
You can't swap the B series DOHC heads on the older D16 blocks
Flip's DC5
Oct 31, 2008 12:27 PM
shoebox
Sep 11, 2006 09:07 AM
Mr Knee
May 21, 2006 09:29 PM
kevslive95
Feb 22, 2005 10:54 AM
JDM_Risa
Mar 16, 2003 01:42 PM
