cluster
Old Jun 4, 2008 | 06:13 AM
ryan_crx's Avatar
Default cluster
i was wondering if my crx cluster will fit into my new ef hatch...the ef dont have a tach and i'm going to be going k in the crx so i wont need that cluster
Old Jun 4, 2008 | 07:30 AM
90efhatch's Avatar
Default Re: cluster (ryan_crx)
I think the crx one is a different size than the hatch one but you can try it.
Old Jun 4, 2008 | 07:56 AM
91_shoebox_Si's Avatar
Default Re: cluster (90efhatch)
might depend on what year your crx and civic are if the connectors for the cluster are different, but it should work fine. all the wires should hook up with no problem and no mods needed. i put a junkyard crx cluster in my 89 civic std and everything, tach included worked just as it should. and no, they are not different sizes.
Old Jun 4, 2008 | 12:38 PM
ryan_crx's Avatar
Default Re: cluster (91_shoebox_Si)
thanks for the help
Old Jun 4, 2008 | 12:43 PM
zcmotor's Avatar
if the civic dont have a tach how would u connect a crx cluster into the civic dont you need a cable for the RPM ?
Old Jun 4, 2008 | 12:48 PM
ryan_crx's Avatar
Default Re: (zcmotor)
the cable in it is for the speedo..
Old Jun 4, 2008 | 04:03 PM
Hondasmo's Avatar
I put a 90 Si cluster in my 91 Dx civic and didnt have to change a thing
Old Jun 4, 2008 | 04:04 PM
zcmotor's Avatar
Default Re: cluster (Hondasmo)
So there's no cable for the RPM ??? only one cable which its the speedo right ??
Old Jun 4, 2008 | 04:09 PM
ryan_crx's Avatar
Default Re: cluster (zcmotor)
i took out my cluster for my crx already to do a k swap into my rex and i had to unplug the speedo cable and then like 2 plugs for the for the lights in the cluster and the tach
Old Jun 4, 2008 | 09:23 PM
traxxasx's Avatar
Its plug and play, your already wired for the tach just plug it in you will be fine.
No the speedo cable is only for the speedo.
The rpm gauge is electric, which your plugs already have the wires hooked into them.
turboblack2door
Oct 29, 2012 04:20 PM
HondaHeddie
Sep 8, 2008 07:56 AM
thestiguy
Nov 29, 2005 11:44 PM
