question about cluster plugs
Old Oct 29, 2012 | 03:02 PM
turboblack2door's Avatar
Default question about cluster plugs
my 88 crx has a dc teg cluster in it right now and obviously the speedo isn't working so i want to take it out and put a crx cluster back in it . If I get the plugs from a ef hatch or sedan at the junkyard(since the dickhole before me cut my factory crx plugs off) will they plug right into my 88 crx as long as the hatch or sedan is a 88-91?
Old Oct 29, 2012 | 03:13 PM
4drEF's Avatar
Keyboard Humorist
Default Re: question about cluster plugs
Sounds like a hassle.
Why not just put an Electronic VSS in the transmission and call it a day?
Old Oct 29, 2012 | 03:28 PM
because i have a cable si trans for it
Old Oct 29, 2012 | 03:49 PM
4drEF's Avatar
Keyboard Humorist
You can use the cable or you can use the electronic in the tranny.
Both get the job done, but of course it will depend on the cluster you use.
Here's a write up for how the DC cluster and VSS get installed to a stock CRX
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-89-crx-cluster-swap-how_to-2934506/
As you can see, you are going to be missing mounting tabs and the connectors when you go to put the CRX cluster back in.
There are differences in the 88/89 and 90/91 cluster wiring as well as the cluster and cluster hood.
http://crxcommunity.com/viewtopic.ph...61aa7b6e5f74f3
Old Oct 29, 2012 | 04:20 PM
GRACIAS SEŅOR! I was wanting to keep the dc teg cluster anyways and this is what i was thinking about doing is just using my cable trans with a vss but didnt think i could
zcmotor
Aug 11, 2008 09:24 AM
Project_EF
12
Feb 11, 2005 07:19 AM
joeyandhiscrx
Nov 16, 2003 12:28 AM
justagsr
Jul 24, 2002 01:14 PM
justagsr
Jul 24, 2002 10:10 AM
