going to state refiry , what catilac converter??
Going to the state referee_, which catalytic converter [do I need]??
So I have my appointment this upcoming Friday and I have a question regarding the catalytic converter_. _The car is an 89 civic dx and I'm going to get it bar'd with a B16 as if it were going to be a 94 civic del sol_"B16". _Which catalytic converter do I go with?? _I have a DC header with a 2.25 collector and 2.5 apex piping. _What car do I get the catalytic converter off of to pass smog with no problems?? _I'm going to have flanges put on the catalytic converter so I can just bolt on my test pipe when necessary. _Help is appreciated thnx.
EDIT: Grammer owened me
Modified by SiR Inspired ED7 at 10:32 PM 6/4/2008
im in the same position, im getting my swap bar'd as soon as i get my cat. this is what im using
http://www.planetmagnaflow.com....html
which ref are you going to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 »</TD></TR><TR><TD CLASS="quote">so i have my opoitment this upcoming friday and i had a quiestion reguarding the catilac converter . the car is a 89 civic dx and im going to get it bar'd with a B16 as if it was going to b a 94 civic del sol"B16" wich catilac converter do i go with?? i have a DC header with a 2.25 collector and 2.5 apex piping. what car do i get the catiliac converter off of to pass smog with no probloms?? im going to have flanges put on the catilac converter so i can just bolt on my test pipe when necessary. help is appriciated thnx.</TD></TR></TABLE>
Holy sh*t. I'm really trying to ignore the grammatical errors contained within your post and answer your question.
Any cat will work. Just buy a universal CATALYTIC converter and do exactly what you said, weld on flanges. I passed the ref with a tiny high flow CATALYTIC converter and I was fine.
Make sure you have all of your vacuum lines hooked up correctly and your wiring is legit as well. Refs aren't stupid, contrary to popular belief.
Oh, and don't forget that CATALYTIC converter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 »</TD></TR><TR><TD CLASS="quote">going to state refiry , what catilac converter??
Sorry, had to do it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">
thnx.
You forgot to correct this ^^^^
thnx.
sorry about the grammer
im going to get it bar'd in san diego with a guy named Mike i heard he is really cool to people. My wiring and vacuum hoses are good, engine bay looks stock
Thanks for the heads up.
im going to go get mine ref'd also, its a 91 hatchback si with b16a1 1st gen, I would like to see a picture of the vacuum lines, to make sure they are hooked up correctly. I dont think they are..
Any help would be greatly appriciated...
Well i failed my first try
Here is what i got....
HC (PPM) Max GP Meas
95 286 256 <U>Fail </U> 15mph
60 236 174 <U>Fail </U> 25mph
CO (%)
Max GP Meas
0.58 2.08 0.85 <U> Fail </U> 15mph
0.57 2.07 0.22 Pass 25mph
NO (PPM)
Max GP Meas
726 1981 2020 <U>Fail </U> 15mph
786 1781 457 Pass 25mph
What do you guys think is the problem ? Or what can i do to fix it ?
I have all new Cat, new 02 sensor, & new ngk v power spark plugs gapped at .44.
Modified by SiR Inspired ED7 at 1:39 PM 6/13/2008
Here is what i got....HC (PPM) Max GP Meas
CO (%)
Max GP Meas
NO (PPM)
Max GP Meas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">This was done at the ref? If it was, he didn't tell you what to do to make it run cleaner?</TD></TR></TABLE>
x2. The refs are always SUPER helpful in telling you what to do to fix your issues and how to be better prepared. What did the ref say? What is your timing at?
It when you do a motor swap and go to a state referee to make it street legal to drive. So dont have to worry about getting pulled over and car taken. Which happens in Cali. Isnt all 50 states similar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote">So dont have to worry about getting pulled over and car taken. Which happens in Cali. Isnt all 50 states similar?</TD></TR></TABLE>
Not here in Arizona. I think the only states that have similar requirements are the states which follow CA/CARB smog laws, the only one I can recall off the top of my head is New York, but I know for a fact there are 3 or 4 more.
