going to state refiry , what catilac converter??
Old 06-03-2008, 05:19 PM
SiR Inspired ED7's Avatar
Default going to state referee , what catalytic converter??
Going to the state referee_, which catalytic converter [do I need]??
So I have my appointment this upcoming Friday and I have a question regarding the catalytic converter_. _The car is an 89 civic dx and I'm going to get it bar'd with a B16 as if it were going to be a 94 civic del sol_"B16". _Which catalytic converter do I go with?? _I have a DC header with a 2.25 collector and 2.5 apex piping. _What car do I get the catalytic converter off of to pass smog with no problems?? _I'm going to have flanges put on the catalytic converter so I can just bolt on my test pipe when necessary. _Help is appreciated thnx.
EDIT: Grammer owened me
Modified by SiR Inspired ED7 at 10:32 PM 6/4/2008
Old 06-03-2008, 05:36 PM
jdmpnoy89's Avatar
Default Re: going to state refiry , what catilac converter?? (SiR Inspired ED7)
im in the same position, im getting my swap bar'd as soon as i get my cat. this is what im using
http://www.planetmagnaflow.com....html
which ref are you going to?
Old 06-03-2008, 09:15 PM
thorclark's Avatar
Im glad i dont have to go threw this. I know its needed but, Darn its a pain.
Old 06-03-2008, 09:32 PM
Rainman
SIred91's Avatar
Default Re: (thorclark)
I'm glad I don't have to deal with trying to talk to the above posters in english.....
Holy ****.
Old 06-04-2008, 07:38 AM
crx_si-r's Avatar
just get a cat that is for the obd1 b16 and you should be fine.
Old 06-04-2008, 08:17 AM
nickrps's Avatar
Location: Roseville really smells like poo, pooo, pooo, CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">so i have my opoitment this upcoming friday and i had a quiestion reguarding the catilac converter . the car is a 89 civic dx and im going to get it bar'd with a B16 as if it was going to b a 94 civic del sol"B16" wich catilac converter do i go with?? i have a DC header with a 2.25 collector and 2.5 apex piping. what car do i get the catiliac converter off of to pass smog with no probloms?? im going to have flanges put on the catilac converter so i can just bolt on my test pipe when necessary. help is appriciated thnx.</TD></TR></TABLE>
Holy sh*t. I'm really trying to ignore the grammatical errors contained within your post and answer your question.
Any cat will work. Just buy a universal CATALYTIC converter and do exactly what you said, weld on flanges. I passed the ref with a tiny high flow CATALYTIC converter and I was fine.
Make sure you have all of your vacuum lines hooked up correctly and your wiring is legit as well. Refs aren't stupid, contrary to popular belief.
Oh, and don't forget that CATALYTIC converter.
Old 06-04-2008, 11:47 AM
PHANTOM MENACE
24TEN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">going to state refiry , what catilac converter??
Sorry, had to do it...
Old 06-04-2008, 02:54 PM
nickrps's Avatar
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">
thnx.
You forgot to correct this ^^^^
Old 06-04-2008, 03:03 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: (nickrps)
LOL I was giving the benefit of the doubt and assuming that one was intentional...if it wasn't then F-
Old 06-04-2008, 09:29 PM
Default Re: (24TEN)
sorry about the grammer im going to get it bar'd in san diego with a guy named Mike i heard he is really cool to people. My wiring and vacuum hoses are good, engine bay looks stock Thanks for the heads up.
Old 06-04-2008, 11:57 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: (SiR Inspired ED7)
That's definitely the right guy to go to down here. Southwestern College. Be sure to post up the outcome bro
Old 06-05-2008, 04:42 PM
Default Re: (24TEN)
ill let u guys know
Old 06-06-2008, 11:17 PM
MIGPA26's Avatar
Default Re: (24TEN)
im going to go get mine ref'd also, its a 91 hatchback si with b16a1 1st gen, I would like to see a picture of the vacuum lines, to make sure they are hooked up correctly. I dont think they are..
Any help would be greatly appriciated...
Old 06-07-2008, 05:59 AM
acmoc's Avatar
Off topic but I need help on this too. what cat do I need for a d16a6, it's actually a SOHC ZC non V-tec for a 91 CRX si. Someone told me OBD1, but I'm not sure.
Thanks
Old 06-13-2008, 12:32 PM
Well i failed my first try Here is what i got....
HC (PPM) Max GP Meas
95 286 256 <U>Fail </U> 15mph
60 236 174 <U>Fail </U> 25mph
CO (%)
Max GP Meas
0.58 2.08 0.85 <U> Fail </U> 15mph
0.57 2.07 0.22 Pass 25mph
NO (PPM)
Max GP Meas
726 1981 2020 <U>Fail </U> 15mph
786 1781 457 Pass 25mph
What do you guys think is the problem ? Or what can i do to fix it ?
I have all new Cat, new 02 sensor, & new ngk v power spark plugs gapped at .44.
Modified by SiR Inspired ED7 at 1:39 PM 6/13/2008
Old 06-13-2008, 12:49 PM
PHANTOM MENACE
24TEN's Avatar
This was done at the ref? If it was, he didn't tell you what to do to make it run cleaner?
Old 06-13-2008, 01:50 PM
nickrps's Avatar
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">This was done at the ref? If it was, he didn't tell you what to do to make it run cleaner?</TD></TR></TABLE>
x2. The refs are always SUPER helpful in telling you what to do to fix your issues and how to be better prepared. What did the ref say? What is your timing at?
Old 06-13-2008, 05:47 PM
carnz98gsr's Avatar
might be a dumb question, but what is getting BARed? is it only a CA thing? i've heard it before but never knew what it was
Old 06-15-2008, 02:20 PM
MIGPA26's Avatar
Default Re: (carnz98gsr)
It when you do a motor swap and go to a state referee to make it street legal to drive. So dont have to worry about getting pulled over and car taken. Which happens in Cali. Isnt all 50 states similar?
Old 06-15-2008, 03:34 PM
Default Re: (24TEN)
The ref that i went to didn't tell me how to fix it. All he said was take it to a smog repair shop & then come back.
Old 06-15-2008, 06:44 PM
PHANTOM MENACE
24TEN's Avatar
wtf? that doesn't sound right, a regular smog station won't even touch your car until you have the BAR label on there...
Old 06-15-2008, 07:07 PM
Default Re: (24TEN)
Idk thats what he told me.
Old 06-15-2008, 07:13 PM
MIGPA26's Avatar
Yeah a smog station wont touch my car because its not bar'd by a ref yet. The ref is going to smog it and go throught everything, he told me will take about 1 hour.
Old 06-15-2008, 07:21 PM
PHANTOM MENACE
24TEN's Avatar
Did you make it out here (southwestern) or did you go to your local ref?
Old 06-15-2008, 07:40 PM
bigrob119's Avatar
Default Re: (MIGPA26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 &raquo;</TD></TR><TR><TD CLASS="quote">So dont have to worry about getting pulled over and car taken. Which happens in Cali. Isnt all 50 states similar?</TD></TR></TABLE>
Not here in Arizona. I think the only states that have similar requirements are the states which follow CA/CARB smog laws, the only one I can recall off the top of my head is New York, but I know for a fact there are 3 or 4 more.
Quick Reply: going to state refiry , what catilac converter??
