Uh, this is bad right?
Old Jun 3, 2008 | 03:52 PM
rockcity's Avatar
Default Uh, this is bad right?
Can anyone tell me what this is and what size nut I need to correct this problem? Or anything else I have to do. I know that it is a suspension or steering item but I can't find it in the components section of the helms manual.
Old Jun 3, 2008 | 03:54 PM
EFstyle's Avatar
Default Re: Uh, this is bad right? (rockcity)
its ur sway bar endlink... id just get the energy suspension endlinks...
Old Jun 3, 2008 | 03:57 PM
.Manny.'s Avatar
Touching My Member
its bad, but its good that it didn't pop out. just throw on whatever pieces are missing at you're done
Old Jun 3, 2008 | 04:04 PM
rockcity's Avatar
Default Re: Uh, this is bad right? (.Manny.)
Thanks guys. What pieces ARE missing? Looking at the one on the other side, it appears to be missing only a nut. I think maybe the rubber sleeve has to be forced back through the whole, maybe?
Old Jun 3, 2008 | 04:10 PM
fireant's Avatar
The whole thing can be replaced with an Energy Suspension endlink kit for pretty cheap. Check with autozone.
Old Jun 3, 2008 | 05:11 PM
rockcity's Avatar
Default Re: Uh, this is bad right? (fireant)
Good deal, I'm gonna go get one tonight. The ones listed on autozone.com don't show that they include the through bolt. So I should just need the kit and a nut and I set, right?
Thanks
Old Jun 3, 2008 | 05:12 PM
Loaded Butane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">The whole thing can be replaced with an Energy Suspension endlink kit for pretty cheap. Check with autozone.</TD></TR></TABLE>
+1
Old Jun 3, 2008 | 05:24 PM
rockcity's Avatar
BTW, what component is this listed under in the helms manual?
Old Jun 3, 2008 | 05:39 PM
grog's Avatar
Its in the suspension section, but its pretty hard to spot,look in the front suspension "exploded view" look for the "stabilizer bar"
Old Jun 3, 2008 | 05:40 PM
rockcity's Avatar
Default Re: Uh, this is bad right? (grog)
Ah yes, now I see.
Old Jun 3, 2008 | 05:55 PM
rockcity's Avatar
Am I going to need anything special to install these? Anything other than a floor jack, stands, and a socket set?
Old Jun 3, 2008 | 06:03 PM
grog's Avatar
nope, all you need is a 12mm for the bushings in the middle ( if you plan on removing it for now) and a 14mm deep socket for the endlinks.
and for the time being you could just remove it until you get the new end links
Old Jun 3, 2008 | 06:23 PM
rockcity's Avatar
Thanks a lot man, I've got them now. I'll put them on in the rise. But I have to remove the bar to install them?
Old Jun 3, 2008 | 06:26 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockcity &raquo;</TD></TR><TR><TD CLASS="quote"> But I have to remove the bar to install them?
no you dont have to. just pull the other end link off and it will pivot out of the way
Old Jun 3, 2008 | 06:39 PM
rockcity's Avatar
Understood.
Old Jun 3, 2008 | 06:53 PM
beana's Avatar
if you decide to get the energy kit i suggest you put the front on jackstands so the springs are as decompressed as they get without taking them out and change the whole thing the bushings AND sleeve in the middle you'll need a fairly big pry bar to the the old one out and to put the new one in
Old Jun 3, 2008 | 09:55 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Uh, this is bad right? (beana)
autozone sells energy suspension parts now? sweet..
Old Jun 4, 2008 | 07:32 PM
Default Re: Uh, this is bad right? (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">autozone sells energy suspension parts now? sweet.. </TD></TR></TABLE>
Yup and they have for a while. I got endlinks for my CRX about 4 years ago from autozone.
Old Jun 4, 2008 | 07:37 PM
ONE-CAM-EF's Avatar
werd..i think ima go and check out vatozone..
billabong
Suspension & Brakes
Oct 29, 2010 04:00 PM
g2b2
May 2, 2007 10:37 AM
shhh151
Jan 31, 2007 07:20 PM
civiccpedx
Apr 5, 2005 04:55 PM
96 SOHC VTEC
Jun 17, 2002 07:39 PM
