vtec problem
Old Jun 3, 2008 | 02:02 PM
h2b-ubeezy's Avatar
Default vtec problem
so my friend has a 2000 civic si and his vtec doesnt kick in at all. When ever you get on it u dont hear vtec at all or even feel it help please
Old Jun 3, 2008 | 03:06 PM
NOFX's Avatar
H-T White Ops
Is he throwing a check engine light?
His VTEC probably works fine. It's not the kind of thing that will throw you back in your seat. It's also not "like a turbo" as I've heard in the past.
Old Jun 3, 2008 | 03:30 PM
4doorek96's Avatar
Default Re: (NOFX)
yeah it probably works fine if their is no cel, you cant really feel or hear vtec in a stock si
Old Jun 3, 2008 | 03:44 PM
z6hatchboy's Avatar
Default Re: (NOFX)
x2, but you can deff hear it. If it actually isnt working and you dont a hava cel then check your oil level.
Old Jun 3, 2008 | 03:51 PM
Ice78transam's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">check your oil level.</TD></TR></TABLE>
x3
NOFX's Avatar
H-T White Ops
You might be able to hear it more if you have an intake.
Old Jun 3, 2008 | 04:07 PM
riceburnerryan's Avatar
if you need, you can rev up slowly to the VTEC point and try and listen if you can hear the crossover... but intake or exhaust helps to hear it
Old Jun 3, 2008 | 04:15 PM
z6hatchboy's Avatar
Default Re: (riceburnerryan)
Just so you dont get confused with that, you cant just rev it up and hit the crossover. You'll have to accelerate (have a load on the motor) to hit the crossover.
Old Jun 3, 2008 | 04:32 PM
aguon03's Avatar
Default Re: vtec problem (h2b-ubeezy)
if there is no cell, check your oil level. VTEC aint nothing really special, you can feel a slight jolt but nothing out of the ordinary. If you had an intake, you will definitely hear the crossover as stated above. If you do happen to get one and still feel like it aint kicking in, check your solenoid and oil pressure. Do a search and you will find all the answers you need here. There is probably a million threads of VTEC problems. Good Luck
Old Jun 3, 2008 | 05:35 PM
EquipedWithVtec's Avatar
didnt feel like reading all the posts but, easiest way to see if vtec is working IMO is hooking up a vtec light splice vtec solenoid wire with another wire and run that to the positive side of the LED. Then just run a wire from the negative batt terminal to the negative side of the LED and DRIVE at like 5500 rpms if the light has not come on im sure your vtec isnt working my d16y8 kicks in at 5200 rpms so if the light dont turn on its not working dont leave the LED in cuz sometimes it messes up your car cuz it messed mine up... DONT freak out if that isnt true because i had it in and a week later my CEL is on so i undid the light and the problem was suddenly fixed so yeah...
Old Jun 4, 2008 | 09:16 PM
h2b-ubeezy's Avatar
thanks for all the advise guys
Old Jun 5, 2008 | 05:29 AM
jdm-civicEJ1's Avatar
yeah vtec doent kick in unless the care is moving cant juss sit in ur driveway and rev up and hit vtec all day
Old Jun 5, 2008 | 08:11 AM
chai_ek9's Avatar
Default Re: (jdm-civicEJ1)
lolz. yea thats ture...
breanna*
12
Aug 2, 2006 09:29 AM
xtreme-customz
18
Dec 1, 2005 07:51 PM
greddy13
Oct 24, 2005 10:40 AM
My Db2 AinT JDM
May 18, 2004 09:24 PM
dAng! Kris
Sep 17, 2003 07:13 PM
