96 HX window troubles
Old Jun 2, 2008 | 06:56 PM
skarpenz's Avatar
Default 96 HX window troubles
I read the FAQ on the window tracks, but I'm not sure a lube will help the window from doing what its doing.
The motor works, the regulator has all the teeth on it. When I try to lower the driver side window, the front part dive bombs into the door, followed shortly thereafter by the rear of the window. It is of course off track at this point. Its annoying. When I raise the window I have to reposition it in the track and then jerk it forward and backward while holding the button. Its embarrassing. The passenger side is also suffering from a mild case of the same problem, but still lifts and lowers on its own (for the most part).
I had the door panel off the driver side and it seemed the scissor part of the regulator was loose, so I tightened up the screw there, and then noticed the front track was loose, so I tightened it as well. Still not solving my problem, any ideas?
Old Jun 2, 2008 | 07:50 PM
skarpenz's Avatar
Its gonna rain all day tomorrow, any help is appreciated. I guess if nothing else I'll just lube the tracks tomorrow at work.
Old Jun 3, 2008 | 04:05 AM
skarpenz's Avatar
Help
Old Jun 3, 2008 | 07:20 AM
gmcawd's Avatar
Default Re: (skarpenz)
Try some adjusting. Most of the bolts that hold the window in can be moved and will make a real difference on the way that the window travels. It could just be a problem with the angle that the window travels. You might be surprised with the difference that some silicone lube will make on the rails as well as the regulator. If all else fails hit up a junkyard and grab replacement everything something could be bent to the point that no tweaking will fix. Do a search cause their are some really helpful threads on this.
Old Jun 3, 2008 | 10:42 AM
NOFX's Avatar
H-T White Ops
Sounds like something is either broken or positioned wrong.
Lubing usually just helps with the windows that are stuck or slowing down.
Old Jun 3, 2008 | 12:50 PM
lluks_844's Avatar
Default Re: (NOFX)
Im having the same problem i just need to find what lube to use, I used white lithium grease because someone said its good, but its just made it worse.
Old Jun 3, 2008 | 01:06 PM
NOFX's Avatar
H-T White Ops
I used silicone spray in mine. It worked fine.
Old Jun 3, 2008 | 01:51 PM
sparknutracer's Avatar
hummm im kinda having the same prob cant figure it out the way mine keeps coming off i think i might need a new regulator
Old Jun 3, 2008 | 06:56 PM
skarpenz's Avatar
I just tore it down to nothing tonight and the regular has to be [freak]ed up. Thats the only thing I can think. I'll get a new one at work for 30$ and see whats up. Piece of ****.
i-want-a-crx
Oct 13, 2007 08:41 AM
WhiteOnRice
Jun 23, 2006 04:15 PM
C2daIzZle
16
Sep 9, 2005 05:06 AM
EX-T
Nov 27, 2003 07:26 AM
Berwyn74
Nov 17, 2003 10:21 AM
