ASR subframe brace w/Civic Type R sway bar making loud clicking sounds
Old Jun 2, 2008 | 02:22 PM
LsHoney84's Avatar
Default ASR subframe brace w/Civic Type R sway bar making loud clicking sounds
EM1 99 Si
I just installed the ASR subframe brace w/ Civic Type R sway bar and 2 new oem endlinks yesterday. I took it for a test drive yesterday after installation without any problems-no sounds. This morning I drove the car to work and parked on the 7th floor of the garage. After I got off and headed home, I started to constantly hear dull popping sounds from the back that is really loud inside and out. The sounds are extremely noticeable (sounds if bending) and occurring more than half the time I am driving.
The sounds can be heard when I am making turns and driving on a straight path going over bumps.
What is happening? I followed the instructions and torqued everything to specifications. I torqued it to final specifications after adjusting the preload. I also followed the same set up as my stock sway bar. I do not have washers between the endlinks and the lower control arms and no washers between the endlinks and swaybar. Should this be a problem (Stock did not have washers)?
Do you think it is the endlink ball joint attached to the swaybar?
What is going on??
Old Jun 2, 2008 | 06:03 PM
s2kholic's Avatar
its prolly the ball joints of the endlinks hitting the sway and the lca's since you dont have nay spacers in between.....
Old Jun 2, 2008 | 07:21 PM
Mark D. Surface's Avatar
Default Re: (s2kholic)
Is the exhaust hitting the sway bar? Check for rub marks on either.
Old Jun 2, 2008 | 07:40 PM
LsHoney84's Avatar
Default Re: (Mark D. Surface)
Ill check and post pics as well
Old Jun 2, 2008 | 07:51 PM
96civic_hb's Avatar
Default Re: (LsHoney84)
I didn't install the washers on mine when I installed my asr subframe brace and rear sway...in for pics..
Old Jun 2, 2008 | 09:07 PM
after nine30's Avatar
From: Dont you wanna know, California, United States
Default Re: ASR subframe brace w/Civic Type R sway bar making loud clicking sounds (LsHoney84)
i had tmakesure the sway bar is not hitting the control arms you might of installed the swaybar backwards
Old Jun 2, 2008 | 09:10 PM
count me out's Avatar
* B A N N E D *
look for witness marks.
Old Jun 4, 2008 | 06:16 PM
s2kholic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark D. Surface &raquo;</TD></TR><TR><TD CLASS="quote">Is the exhaust hitting the sway bar? Check for rub marks on either.</TD></TR></TABLE>
this can be it also, my stock exhaust hits the sway mounting brackets......
battmancjz
Jun 3, 2016 06:19 AM
corince06
Oct 4, 2008 08:57 PM
AlxSiR7
Suspension & Brakes
Jan 9, 2005 12:45 PM
PapiTuyo326
Dec 1, 2004 12:01 PM
