ive got some play with my lsd, is this normal?
Old Jun 2, 2008 | 01:40 PM
blackeg's Avatar
Default ive got some play with my lsd, is this normal?
when i had my axles and axle seals out the other day i noticed my differential seemed like it had a lot of movement. if i put my finger in where the axles go in i could move it up and down somewhere between 1/8 and 1/4 inch. with the axle seals back in, it moved but much less. is this normal? btw its a newer style obx lsd that was retorqued before installation
Old Jun 2, 2008 | 06:04 PM
Agnom's Avatar
Default Re: ive got some play with my lsd, is this normal? (blackeg)
Did you use the tapered roller bearing or enclosed bearing?
Old Jun 3, 2008 | 06:03 PM
blackeg's Avatar
Default Re: ive got some play with my lsd, is this normal? (Agnom)
not sure, the diff was in the trans when i bought it. im likened to say tapered roller because with the axle seals out i can see the ***** in the bearing, im assuming making it not enclosed
Old Jun 5, 2008 | 06:19 PM
blackeg's Avatar
ttt
Lockner13
Feb 29, 2012 06:57 PM
blackeg
Apr 29, 2011 09:15 AM
AFAccord
Transmission & Drivetrain
Jan 29, 2009 04:27 PM
longuyen88
Jun 16, 2006 09:41 PM
Dgr8wun
Jul 30, 2003 11:38 PM
