CEL ...problem
Old Jun 2, 2008 | 10:45 AM
delsolcharli's Avatar
Default CEL ...problem
ok first i thought it was 7 and 24..there isnt a 24 cel though..anyways
i used a jumper
this is on a gsr ..started it up today
anyways this is the code i got guys...
7 short 1 long ..kinda a pause ..1 long 4 short
which i thought it was 7 and 24
but is it 17 and 14
vss and iac
Old Jun 2, 2008 | 11:01 AM
Default Re: CEL ...problem (delsolcharli)
http://www.youtube.com/watch?v=_OGzPFT_ugo
video of it starting up..sounds like **** on the video...but i have no intake on it right now and i just wanted to crank it up to see if it threw codes...and it did
Old Jun 3, 2008 | 09:16 PM
Old Jun 3, 2008 | 10:14 PM
civicdriverzero1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolcharli &raquo;</TD></TR><TR><TD CLASS="quote">ok first i thought it was 7 and 24..there isnt a 24 cel though..anyways
i used a jumper
but is it 17 and 14
vss and iac</TD></TR></TABLE>
There is an entire section on CEL codes - but I'll try and explain how it works here.
Any time you are interpreting a CEL code it it going to give you the numbers in succession from first to last in numerical order. ( example: 7, 15, 28 etc.)
With that in mind - any time there is a pause then a new number has begun or it is starting the sequence over again.
AND very importantly you wont ever see a number that starts with SHORT blinks unless it's a SINGLE digit code.
SO I would like to say in your case that you are most likely throwing a:
code 7 Throttle Position Sensor (TPS)
code 10 Intake Air Temperature Sensor
code 14 Idle Air Control Valve
Someone correct me if I'm wrong - maybe a video of the CEL blinking out the codes would help a great deal since you are inexperienced with deciphering the codes.
Hope I was able to help
Old Jun 3, 2008 | 10:48 PM
Default Re: CEL ...problem (civicdriverzero1)
ive done it in shop before, but never more than one code, it was throwing me off when i had short and fast, then fast and short..or however it was.
Old Jun 3, 2008 | 10:49 PM
O yall wanna see what my transmission looked like i got from Steve at Hmotors.
thats what i do for a living..find cracks..got some stuff from work to show it better
motoracer951
Aug 5, 2012 06:49 PM
tdo
Aug 11, 2009 07:46 PM
cltitus
Jun 16, 2007 08:14 AM
BI8B
10
Mar 27, 2006 10:48 AM
AnNiMosSiTY
Feb 6, 2003 02:58 PM
